Old 05-21-2014, 06:23 PM   #1 (permalink)
What did I just do?!
Rishar's Avatar
Angry Bird - '10 Toyota Prius
90 day: 62.27 mpg (US)
Playing with technique
Started trying something a little different today to see what I could get on the over time display, so far, I'm liking this one.
The Following User Says Thank You to Rishar For This Useful Post:
Cobb (05-21-2014)
Old 05-21-2014, 07:19 PM   #2 (permalink)
Good job. Experiment with acceleration. Many gen 2 insight owners have discovered you can be more aggressive up to 2500 rpms before vtec kick sin and still get great fuel economy.
The Following User Says Thank You to Cobb For This Useful Post:
Rishar (05-21-2014)
Old 05-21-2014, 07:25 PM   #3 (permalink)
Rishar's Avatar
Acceleration is where I was/am having the biggest issue figuring out. The when, how much, etc etc. It's a pain to find a good spot. And of course, I made the mistake to comment on how nice the weather was when I left home(65 and nothing but sun)...because 20 minutes later, downpour. XD
Old 05-21-2014, 08:29 PM   #4 (permalink)
Cool
Yup, accelerate with gas and coast with electric to extend your glides.
Rishar (05-21-2014)
Old 05-21-2014, 08:40 PM   #5 (permalink)
Rishar's Avatar
Not much opportunity for glide as this is all highway (and a Prius which wants the engine turning above 41). Below 41 where I can P&G I've got a pretty good average of around 85-90 but almost all my driving is highway. I drive about 170 miles 4 days a week, so getting my SHM down is of high importance.
Old 05-21-2014, 08:47 PM   #6 (permalink)
What is your highway posted limit and average traffic speed? For example 55/65? Go accelerate to 65, then apply light throttle to assist in coasting down to 55 or even 50 depending on traffic and repeat. This is what the lean burn guys do to get triple digit mpg. Of course they hover around 50 mph.
I know people say the car exits use of the electric motor and goes to gas at certain speeds, but it does cut off the engine under light load at and above highway speeds.
May help to use the rpm feature and start setting rpm limits for gas usage when accelerating. The insight has a big honking one in the center of the dash and I try to stay below 2500 or just before vtec kicks in yo.
Old 05-21-2014, 09:05 PM   #7 (permalink)
Rishar's Avatar
Limit is 55 and barely any traffic, so going above is a good way to get a ticket as you can't blend in with the flow :P.
Best I've seen from anyone in the Gen 3 is around 75 (average). But yes, that is what I do. Accelerate up to about 57, then hold rpm around 1080 until down to 50 or so, then back up to speed. I'm still trying to find the best speed to accelerate at. So far, no guide I can find has supplied this particular info except for a blog that bases it on %pedal depression. o.o
Old 05-22-2014, 08:35 PM   #8 (permalink)
In that case just set the cruse control for 45 mph and enjoy the ride.
The gen 2 insight seems to get best mpg between 45 and 55. I set the cruse for 56 in 55 zone if traffic is light. If its little to no traffic I go slower 45-52. If traffic is heavy I go with the flow.
Old 05-22-2014, 09:29 PM   #9 (permalink)
Rishar's Avatar
Bah! Sounds like cheating. :P
Old 05-22-2014, 09:58 PM   #10 (permalink)
Its repeatable. If you set the cruse control and reset the odo and just steer the car for x amount of space. Then make a mod or change and repeat.
Most of my mod testing was done this way.
