Old 05-25-2014, 03:49 AM   #1 (permalink)
zingaro's Avatar
z - '13 Honda CRZ
Global - '12 Dodge Ram Cargo Van
60 mpg on the horizon
maybe on this 500 mile run, if the temps stay up
Old 05-25-2014, 12:53 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Congrats!
What's the front licence plate?
Old 05-25-2014, 06:26 PM   #3 (permalink)
TheManVan's Avatar
Wow getting so close! Really nicely done!
Old 05-25-2014, 06:33 PM   #4 (permalink)
zingaro's Avatar
z - '13 Honda CRZ
Mabye Perg Austria, but for sure ebay. I wanted all yellow to go with my scheme but it was $20 as opposed to $6. For $20 I could almost buy enough gas to drive there !!!!!
Old 05-30-2014, 04:16 PM   #5 (permalink)
zingaro's Avatar
z - '13 Honda CRZ
nothing more nothing less
a little more n a little more
a little less n a lot more
NOw that the temps are coming up the air density is decreasing: good for the aerodynamic but bad for the performance. Between my home and a flea in SC theres a 6 % grade. Great going down but now going up I have to use 4 th gear instead of 5th. Im still running the blocking plate in front but because of the high IAT the ignition retards to below 10 degrees BTDC so I cant maintain 52 mph in 5th gear. I usually downshift before the ecu shows the downshift lite ( I think it comes on at 6 degrees BTDC)
IN the pic below the SC is showing 31 degrees ignition timing but if I could of caught the whole panel youd see one bar of charge
`13 Honda crz k&n dropin, muffler, rear, right wiper delete, front block off plate, WAI (130f), 50 psi TP, NON eth gas
