Old 07-20-2023, 10:32 AM   #11 (permalink)
Ahhh that caused me to recall my brother had a steel capped left boot they drug when he did flat track dirt racing around the turns
freebeard (07-20-2023)
Old 07-25-2023, 05:49 PM   #12 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
For me its just repetitive movements. I think I have pre-arthritis at this point. Knees, hips, back, wrist.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 07-26-2023, 05:01 PM   #13 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Congrats on the new bike. Craig Vetter did a fairing for the KLR. I don't know if it made it to production as a kit.
Old 07-26-2023, 05:03 PM   #14 (permalink)
JSH
AKA - Jason
JSH's Avatar
Stepping with one foot on the ground while cornering, which is quite usual.
Not for street riding. That is a flat-tracking / supermoto / motocross technique
Old 07-27-2023, 01:32 AM   #15 (permalink)
Since the OP mentioned motorcycle camping, maybe that technique would still be occasionally required while riding on rough terrain.
Old 08-07-2023, 02:50 PM   #16 (permalink)
Talk to Schultz Engineering about Craig Vetter fairings. A front fairing and a tail section give the best drag reduction. An e-bike will start about $3000.
Old 04-09-2024, 10:34 PM   #17 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
For any of you KLR owners out there, the KLR has a cheaply designed cooling setup without a bypass. So the thermostat cycles open and closed constantly, causing the cold radiator coolant to get introduced to the bottom of the engine and sit there until the coolant at the top of the engine gets hot enough to open the thermostat where the cycle repeats again.
If you've done any reading about the fancy dual circuit cooling systems on some newer car engines that run a separate engine block circuit at a higher temperature than the head for fuel economy purposes, you should know where this is going. Cold coolant in the block is the opposite of what you want, and can lead to worse fuel economy and the cylinder not wearing evenly, thus oil consumption.
The "Thermobob" from wattman solves these problems, adding an external thermostat with a proper bypass, and a hotter thermostat than the stock bike.
https://watt-man.com/new-shop/thermo...0-model-years/
There is also a great breakdown article on testing the thermobob in the 'Thermo-Bob FAQ' tab up at the top. A very nice technical analysis of why the stock system sucks and how much a proper bypass circuit improves things.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 04-09-2024, 11:18 PM   #18 (permalink)
90 day: 29.78 mpg (US)
I drove my best friend out to Eastern Oregon one night in my parents Toyota Camry to pick up a KLR650. The car overheated and most of the coolant was lost, so we debated if we should drink the emergency water and pee into it, or just put the emergency water in the radiator. We decided to use the water directly in the radiator and that got us to the destination filling it a couple times.
The next day, we went to the parts store and got a new radiator cap, then picked up the bike. My friend didn't have his endorsement yet, so I rode it back while he drove the car. He's still got the thumper.
Old 04-10-2024, 05:14 PM   #19 (permalink)
You know I've always heard this but the bikes already last too long.
