Old 04-12-2009, 12:31 PM   #1 (permalink)
Pressure thrust?
Check this out. Could be of major import, but certainly provocative:
Pressure Thrust
Theory holds that in aft body, pressure recovery can be used to provide negative drag, or thrust. NASA per Goldschmied and Bushnell have worked on this, with potential for major fuel savings.
Please do a little Googling with keywords "pressure thrust," "David Birkenstock," "Goldschmied," read what they have to say, and discuss here.
The Following User Says Thank You to Otto For This Useful Post:
Logic (Yesterday)
Old 04-12-2009, 02:59 PM   #2 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
an interesting idea... i've always wondered it it was possible to design a sort of "wing"in the broad sense of the word, that in stead of generating lift at the top would generate pressure at the end... there would naturally be a loss of energy, but if this shape could be roughly car like than you'd have a car that in stead of having drag at the end would have pressure at the end.
a quick google search generated this image
wich reminded me of something else... this:
i admid a rather loose association, but still....
Old 04-12-2009, 04:43 PM   #3 (permalink)
- - '10 Toyota Prius III w/Navi
Hi All,
Does the figure in the OP's link remind anybody of a Saab 900 ?
Old 04-12-2009, 06:23 PM   #4 (permalink)
What about the direction of the pressure?
Old 04-13-2009, 02:31 AM   #5 (permalink)
now you mention it, however the saab 900 actually wasn't so aero as veryone wants to believe it's cd was around 0.40 if i remember correctly... the big whale spoiler helped a lot to improve that though.
a rather square body with this saab like rear angle is know as a morell body, i don't have much info on it, but basically the sides act like two vortex generators wich produce two large counter rotating vortices... this is quite bad for aero.
this body style was quite comming in the 70's and 80's and you frequently see these cars have spoilers installed below the windshield to reduce the size of the vortex... usually the Cd numbers of car with and without the spoiler are vastly appart .
Old 04-13-2009, 03:01 AM   #6 (permalink)
Who remembers that car as aerodynamic? It's like a Cherokee, but with a sloped back.. Actually the windshield is more vertical than a Cherokee's
Old 04-13-2009, 06:53 AM   #7 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Here's a link to aircraft design: Pressure Thrust- The Future of Aviation? | Airliners.net
It features the cad drawing as per an earlier post but also some interesting reading on it's use on aircraft. Could the efficiency figures quoted be any way close? If so then this concept needs to go mainstream NOW!
ollie
Old 04-13-2009, 09:44 PM   #8 (permalink)
My grandpa once told me that a properly-designed full engine cowling on a radial-engined airplane actually pulled the airplane forward a bit. Sounds like the same sort of idea.
(Boy do I miss him!)
-soD
Old 04-13-2009, 10:48 PM   #9 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Looks like a bullet. Which, consequently, is about the same shape as a missile or an older bomb. And now you know where the technology will rear it's head first.
Old 04-14-2009, 05:55 PM   #10 (permalink)
Several Bonneville salt flats racers have toyed with the idea of racing a Posche 928 in one of the factory production classes...
but running it with the body on backward!
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Relative tire pressure? bwilson4web EcoModding Central 4 03-16-2009 10:35 PM
