Old 05-03-2023, 06:46 PM   #201 (permalink)
I use them when I am towing standard width trailers in my F250
vs
better visibility, but then you can't use your visors.
Each of these is not like the other.
A five-panel Wink mirror is a sun visor. I leave a little gap above so I can see traffic lights.
Old 05-03-2023, 10:37 PM   #202 (permalink)
Originally Posted by Blacktree View Post
It feels good crossing stuff off the to-do list.
I can only imagine!
Name:	Driving off into the sunset.jpg
Old 05-09-2023, 10:53 PM   #203 (permalink)
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
I was able to finish the fog light install. I realize this isn't related to hypermiling, but it does involve the car. And if I didn't say anything about it, people would probably ask anyway. So here we go!
My car didn't come with fog lights, so I decided to retrofit them. We're using stock replacement fog light housings, along with a relay box and wiring pigtails from a Prius (in the junkyard) that has factory fog lights. So basically, all I need to do is run some wires to connect the dots, so speak.
However, I decided not to use the stock fog light switch. Plus I went with LED bulbs. The LED bulbs tend to be extra bright, so I got an LED dimmer. Using a rheostat with LEDs can be problematic, so we're using a PWM unit instead.
In the photo below, I'm getting ready to transfer the fog light relay and wiring from the junkyard relay box to the one in my car.
Now the wires are transferred over. You're looking at the backside of the relay box. De-pinning those wires was kind of a pain, because I didn't have the special tool. But the pocket screwdriver eventually got it done.
Power for the fog lights was routed from the main fusebox in the engine bay. There's a battery terminal in there, which is convenient. I'm not a big fan of watching my car burn down. So I used an inline fuse.
At this point, the wiring in the engine bay is done. Here's a shot of the engine bay. That yellow wire is ground for the relay. I could have run it somewhere out of sight, but got lazy.
Now we go inside the car...
The PWM controller has a knob for adjusting the brightness. I decided to install it on the kick panel below the steering column. It won't be used very often, so it doesn't need to be up on the dash. I also found a convenient place to mount the PWM circuitboard.
As mentioned above, I'm not using a manual switch for the fog lights. Instead, they will come on with the running lights. So I tapped into the running light wiring, to activate the fog light relay. In the photo below, you're looking at the electrical plug for the rheostat that controls the brightness of the dash lights. That gray wire on the right comes from the headlight switch. It has power when the running lights or headlights are on. And that's exactly what I want.
In the photo below, the wiring is hooked up to the PWM dimmer. And that finishes the wiring.
The kick panel is reinstalled. Now you can see the dial knob.
And last but not least, the money shot! The fog lights are pretty bright, even with the brightness at 50%. Good thing I installed that dimmer...
Not sure why, but on camera the fog lights look more yellowish. In real life, they're more of an amber color. Which is good. The amber color is more pleasing to my eyes.
Old 05-09-2023, 11:40 PM   #204 (permalink)
Is fog a regular problem in your area?
Old 05-10-2023, 12:30 AM   #205 (permalink)
Blacktree's Avatar
The yellow / amber color range is very easy on my eyes. But yellow / amber headlights aren't legal in my area. So I use amber fog lights to add some of that color.
Plus I think they look cool.
Old 05-10-2023, 12:57 AM   #206 (permalink)
I think this guy is hilarious. He had a Prius for almost a million miles, although his Prius jokes weren't as great as the rest.
He talked about setting up lights on the front of a Prius to look like a big truck at night and then you pass people and laugh:
Old 05-10-2023, 01:52 AM   #207 (permalink)
Daytime Running Lights?
In the 1980s log trucks and Greyhound buses had little pools of yellow light in front of them. My VW bus with Hella H-4s had white light wall-to-wall and 80 ft in the air.
Old 05-10-2023, 10:51 AM   #208 (permalink)
Blacktree's Avatar
Basically, I'm going to use them like DRLs. But technically they might not be considered DRLs, because they don't come on automatically with the ignition. They come on when I turn on the running lights.
They're setup like that, because I want to be able to turn them off. But I don't want an extra switch to contend with. Having the fog lights piggyback on the running lights jives with my feng shui.
Also, the dimmer knob is basically a "set it and forget it" type of thing. I'll fiddle with it until I find the optimal brightness, then leave it there. It's the same thing I did with the Jetta. And it worked nicely.
The Following User Says Thank You to Blacktree For This Useful Post:
freebeard (05-10-2023)
Old 05-11-2023, 04:36 PM   #209 (permalink)
Blacktree's Avatar
BTW, I also retrofitted a backup camera. I found a Prius in the salvage yard with a factory backup camera, and snagged it.
Also, my dash exploded! I finally got around to installing that Android head unit. Replacing the Prius radio is quite the job.
I decided to install the fog lights and backup camera now, because the dash had to come apart for the Android head unit installation. And both of those things involve doing some wiring inside the dash. This way, I only have to take apart the dash once. Now that these upgrades are done, we can get back to the ecomods.
Old 05-11-2023, 04:54 PM   #210 (permalink)
Some weirdo on YouTube decided he was rather upset about it.
How do you like the upgrades?
