Old 04-05-2009, 09:32 PM   #31 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
My only fear with strapping through the spokes is that brake calipers frequently come very close to the inside of the wheel. If the wheel or bearing flexes at all in a hard turn, there goes your cover, and if you used metal strapping, you might damage something too. But if you are absolutely sure you have clearance, it is a great idea.
If you have room to strap through the spokes, I would think about using these. You can get them from McMaster-Carr or various other places. I used a bag of them to join 2 umbrella strollers into a double stroller. Make sure to size them so they snugly fit around the wheel spoke. Then if you ever want to remove them, the wheels will not be all scratched up. Use a full threaded bolt, and put the head of the bolt on the side with the sharp bend. Use a bolt long enough to reach past the outside of your wheel cover. Put the clamp around the spoke, and tighten a nut on it to get the clamp down good and tight over the spoke. Then drill a hole in the wheel cover in the appropriate place. You should have at least 3 holes. Another way to go about it would be to use a short bolt and instead of a nut, use a nut coupling. Then instead of having protruding studs with nuts, you could attach the wheel cover with more aero button head screws.
If there is no room to safely attach through spokes, someone from a thread long ago suggested a good idea. Get some lugnuts that are solid on the ends, and drill and tap the ends for bolts. Then drill your wheel covers appropriately. You can use button head bolts to be more aero. Lugnuts are about $1 apiece at the parts store, or you could probably scrounge a used set from the junkyard for almost nothing.
Winter daily driver, parked most days right now
Summer daily driver
Old 04-06-2009, 12:43 AM   #32 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
wagonman76 -
Thanks for the detail tip. I am going to spend additional time staring at my disk brake/wheel relationship.
CarloSW2
American Solar Energy Society
Old 04-08-2009, 06:01 PM   #33 (permalink)
SVOboy, did you settle on a solution?
Old 04-11-2009, 12:12 PM   #34 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
As pointed out, it's not a question of "if" a snap-on wheel cover will come off, but when.
I have 16" full-moon discs (push-on) on my '06 Civic and just lost one somewhere between Albany and New Milford Pennsylvania ... a 180 mile stretch.
It's pretty disappointing as I've had these less than a year. So, do I buy a replacement for $25-30 ... or just give up on these and try something else.
I'd like to get a set of rear wheel skirts and then I'd only need two discs for the front wheels ... but I'm not seeing well made skirts available anywhere and I'm just not able to hobble something together to my satisfaction.
I'd go the alloy route if I could find something reasonably priced and very aerodynamic.
--- Bror Jace
Old 04-22-2009, 11:16 AM   #35 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Volkswagen Rabbit S
90 day: 33.97 mpg (US)
thinking about this... couldn't you have "aftermarket" longer studs installed, like those someone would use for thicker aftermarket wheels or wheel spacers. Put your lugs on like normal, then use the remaining stud sticking out as standoffs to bolt on your disc?
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 04-22-2009, 11:48 AM   #36 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 36.15 mpg (US)
That would work, but replacing 16-20 studs is a pain to do. If you only did 2 on each wheel (for a 4 stud hub, at least), then you could do the opposite studs, and save some work.
I like the center cap system on that Regal. I don't think I'd trust a normal center cap that isn't bolted on like that one though.
Old 06-05-2009, 12:51 PM   #37 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I attached my second edition moon discs with 4 zip ties aroud wheel spokes. I got aluminiun wheels so old ones didint fit anymore. New glasfibre discs are 300g each lighter. New disks are in balance in hinger speeds also. I will update my results if those will fall off. At the moment I think those are more aerodynamic than the previous version. Pictures will follow also.
Old 06-06-2009, 05:14 PM   #38 (permalink)
noxman's Avatar
Hi!
I was thinking about clean smooth disc cover.
Ideal is buy plastic cover with classic steel ring mounting like on the 1 picture.
Because i have any size than the clean plastic cover ( 14' vs 13' is shame for me :-() i thinking about buy some cheaper plastic cover with holes.
That holes will be covered with textile universal tape.
1.Fiat Punto 1.1 8v 40 Kw - 1996. 4l/100km with external board computer http://www.youtube.comwatch?v=P0Eq_m1VhBQ
2.Fiat Punto 1.2 8V 44kw - 2002, LPG injection system, trying to be eco... Video shows my lpg system and ride.
http://www.youtube.com/watch?v=FlQ-Xl6aIj0
Old 06-06-2009, 05:21 PM   #39 (permalink)
Where is that plastic cover from??
Old 06-06-2009, 07:08 PM   #40 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
winkosmosis -
I followed the JPG here :
Anglia-Trading.cz - tuning, autodoplňky & nářadÃ*
Can't find an english-language option, though, .
CarloSW2
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
