09-05-2020, 06:12 PM
#11 (permalink)
Not an informed guess but if I was piloting that through the Oz-tralian Outback, I'd want downforce, just in case.
Zero yaw is a momentary condition.
FYI: EcoModder has a polling function.
So that's a (1)?
09-05-2020, 06:23 PM
#12 (permalink)
Must I say it? Would that make me right?
I vote for
New Thread: Post a Poll
Yes, post a poll with this thread
Number of poll options: 4 (Maximum: 10)
.tragectory: Line goes down and to the right.
09-05-2020, 08:49 PM
#13 (permalink)
1 or 2?
09-07-2020, 04:48 AM
#14 (permalink)
No other entries? I'll give it a few more days.
09-07-2020, 05:19 AM
#15 (permalink)
Eco-ventor
Whenever you post the answer I'll just edit my guess.
The Following 3 Users Say Thank You to jakobnev For This Useful Post:
09-07-2020, 05:29 AM
#16 (permalink)
Summary so far (no edits)!
(1) Downforce
(2) Neither lift nor downforce
(3) A small amount of lift
(4) A lot of lift
California98Civic - 5 (I assume therefore 4)
Redpoint5 - 3
Jakobnev - 3.5
Oil pan 4 - 3
Jimhs - 4
Green TDI - 3-4
Freebeard - 1
Ksa8907 - 1-2
09-07-2020, 09:29 AM
#17 (permalink)
Can we see a picture of the underside? Or is that irrelevant?
My guess is that it will take off at highway speed
09-07-2020, 12:54 PM
#18 (permalink)
Thank goodness for email notifications. I will have forgotten by then.
09-07-2020, 03:41 PM
#19 (permalink)
1 or 2, bu if I had to pick...2
09-07-2020, 04:00 PM
#20 (permalink)
To expand on my guess, without editing my post...
I would assume that downforce would work out to mean more rolling resistance, as the vehicle would behave as if it's heavier the faster you go...
Therefore neutral would be better for FE, presumably. And no loss of traction at speed. Of course, if it only weights 50lbs, you might want downforce at speed to keep you grounded. Bad things might happen when you catch air, though...
If it's heavy, they might have designed it for a bit of lift, to reduce RR the faster it goes.
Too much lift sounds like a bad idea in general.
Of course, if it only goes 30km/hr, lift and the Cd are both pretty moot points...
YMMV.
