Old 02-26-2025, 11:58 PM   #1421 (permalink)
You might want to be more specific.
Indeed. I was considering the easy access to the engine, compared to some newer cars which must be almost dismantled in order to reach some component requiring a replacement
The battery location is another example of being "too simple" to be practical.
Other than rendering a jump-start more difficult, I wouldn't be so concerned about the battery location in a Beetle if I had one.
Old 02-27-2025, 01:10 AM   #1422 (permalink)
The battery sits on the floor. The floor is prone to rust. The battery is prone to fall through the floor and drag on the ground.
You can't be wise and in love at the same time. -- Bob Dylan
Old 02-27-2025, 10:17 AM   #1423 (permalink)
The battery is also prone to leaving an acid trail that causes the floor to rot after attacking even the tar goop that is part of manufacture.
Never had one fall on the ground. Had a seat try to catch fire...... both scenerios stopped by keeping a plywood sheet between the battery and the world, top and bottom.
freebeard (02-27-2025)
Old 03-01-2025, 08:02 AM   #1424 (permalink)
When people sat in the rear of my Super Beetle (passenger side) they complained about the seat being warm.
I looked into it and found out the metal seat springs were making contact with the battery terminals when the seat was sat on.
I think I weighed only 125 lbs at the time and it was not not a problem for me, only discovered issue when bouncing on the seat.
My solution was a piece of corrugated cardboard to break the contact.
Old 03-02-2025, 02:13 PM   #1425 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Simple seat heater with auto-off when unoccupied.
Nice
The Following User Says Thank You to Piwoslaw For This Useful Post:
freebeard (03-02-2025)
Old Today, 01:09 AM   #1426 (permalink)
Sure it has some downsides, but it's no rocket-science to overcome them.
Old Today, 02:10 AM   #1427 (permalink)
..no rocket-science
An old parking sign is just about the right size.
