07-08-2022, 10:29 PM
#31 (permalink)
https://youtu.be/Mi5NgRyAqt4
https://youtu.be/Zq2KjcNE50c
two videos showing a flat floor isnt necessery. it helps a little and is better than a dirty floor, but the diffuser helps all cars
The Following User Says Thank You to Phase For This Useful Post:
07-11-2022, 11:30 AM
#32 (permalink)
youtubes
I don't know anything about this person.
I don't know anything about the CFD he uses.
The models he depicts do not represent any 'reality' I've ever experienced.
Perhaps, when I have nothing else to do, I can spend some time vetting him, but until then , I find his conclusions highly dubious.
There's some 'context' associated with his presentation, however there's no transparency provided in its content.
07-11-2022, 12:39 PM
#33 (permalink)
Those are two different people doing two different tests
Bottom line is yes, a flat floor is best, but you don’t need a flat floor for a rear diffuser to work
07-11-2022, 01:27 PM
#34 (permalink)
The first video is someone I'm familiar with. He does this stuff (aerodynamics engineering) for a living. So there's a pretty good chance he actually knows wtf he's talking about.
The second video, I'm not familiar with. So I can't comment.
The Following User Says Thank You to Blacktree For This Useful Post:
07-11-2022, 01:52 PM
#35 (permalink)
don't need
It flies in the face of all previously published foundational research. And I don't understand the rush to dismiss what, up to now has been considered 'settled science.'
So, like something the late Carl Sagan might say, it would require a remarkable argument.
07-11-2022, 01:59 PM
#36 (permalink)
chance
When I can, I'll try and dig up a portfolio on the guy.
Some CFD I've seen, like Air Shaper, produces quanta which doesn't resonate within this universe. Orders of magnitude.
07-11-2022, 02:31 PM
#37 (permalink)
i mean its not as perfect as an EV, but other than the rear section, it seems like its pretty streamlined for an underside
07-11-2022, 03:09 PM
#38 (permalink)
DrivAer model
Here's a link to Munich's model:
https://www.researchgate.net/profile...r-OpenFOAM.pdf
For the notchback smooth underbody model, CFD was 4.26% different than wind tunnel.
Same car, but with detailed underbody, the CFD was 11.18% different than the wind tunnel model.
Reason: add data
07-11-2022, 03:55 PM
#39 (permalink)
'smooth' vs 'dirty'
I went to the Munich, Germany site.
I reverse-engineered an estimated frontal area.
I reverse-engineered the VERSUS ENGINEERING test velocity.
Using Munich's drag coefficients for the wind tunnel tested-model, I reverse-engineered for VERSUS's velocity.
With their own numbers, I calculated that the 'smooth-bellied' notchback with diffuser would have 39.1 fewer counts than the 'dirty-bellied' notchback with diffuser, making 13.82% lower drag.
With only the smooth belly and diffuser, the IONIQ might hit it's target of Cd 0.20.
07-11-2022, 09:03 PM
#40 (permalink)
Why’s the Ioniq ev got the same or higher CD then if that has a smooth flat under body and a mini rear diffuser? That’s what I don’t get
I’m pretty worried about cooling when trying to cover the underbody mufflers and exhaust pipes
