Old 07-08-2022, 10:29 PM   #31 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
https://youtu.be/Mi5NgRyAqt4
https://youtu.be/Zq2KjcNE50c
two videos showing a flat floor isnt necessery. it helps a little and is better than a dirty floor, but the diffuser helps all cars
The Following User Says Thank You to Phase For This Useful Post:
aerohead (07-11-2022)
Old 07-11-2022, 11:30 AM   #32 (permalink)
youtubes
I don't know anything about this person.
I don't know anything about the CFD he uses.
The models he depicts do not represent any 'reality' I've ever experienced.
Perhaps, when I have nothing else to do, I can spend some time vetting him, but until then , I find his conclusions highly dubious.
There's some 'context' associated with his presentation, however there's no transparency provided in its content.
Old 07-11-2022, 12:39 PM   #33 (permalink)
Phase's Avatar
Those are two different people doing two different tests
Bottom line is yes, a flat floor is best, but you don’t need a flat floor for a rear diffuser to work
Old 07-11-2022, 01:27 PM   #34 (permalink)
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
The first video is someone I'm familiar with. He does this stuff (aerodynamics engineering) for a living. So there's a pretty good chance he actually knows wtf he's talking about.
The second video, I'm not familiar with. So I can't comment.
The Following User Says Thank You to Blacktree For This Useful Post:
Old 07-11-2022, 01:52 PM   #35 (permalink)
don't need
It flies in the face of all previously published foundational research. And I don't understand the rush to dismiss what, up to now has been considered 'settled science.'
So, like something the late Carl Sagan might say, it would require a remarkable argument.
Old 07-11-2022, 01:59 PM   #36 (permalink)
chance
When I can, I'll try and dig up a portfolio on the guy.
Some CFD I've seen, like Air Shaper, produces quanta which doesn't resonate within this universe. Orders of magnitude.
Old 07-11-2022, 02:31 PM   #37 (permalink)
Phase's Avatar
i mean its not as perfect as an EV, but other than the rear section, it seems like its pretty streamlined for an underside
Old 07-11-2022, 03:09 PM   #38 (permalink)
DrivAer model
Here's a link to Munich's model:
https://www.researchgate.net/profile...r-OpenFOAM.pdf
For the notchback smooth underbody model, CFD was 4.26% different than wind tunnel.
Same car, but with detailed underbody, the CFD was 11.18% different than the wind tunnel model.
Old 07-11-2022, 03:55 PM   #39 (permalink)
'smooth' vs 'dirty'
I went to the Munich, Germany site.
I reverse-engineered an estimated frontal area.
I reverse-engineered the VERSUS ENGINEERING test velocity.
Using Munich's drag coefficients for the wind tunnel tested-model, I reverse-engineered for VERSUS's velocity.
With their own numbers, I calculated that the 'smooth-bellied' notchback with diffuser would have 39.1 fewer counts than the 'dirty-bellied' notchback with diffuser, making 13.82% lower drag.
With only the smooth belly and diffuser, the IONIQ might hit it's target of Cd 0.20.
Old 07-11-2022, 09:03 PM   #40 (permalink)
Phase's Avatar
Why’s the Ioniq ev got the same or higher CD then if that has a smooth flat under body and a mini rear diffuser? That’s what I don’t get
I’m pretty worried about cooling when trying to cover the underbody mufflers and exhaust pipes
aerohead (07-14-2022)
