03-02-2014, 11:23 AM
Rear lip: aerodynamics better or worse?
Hi
I am thinking of putting a original rear lip civic ek9 in my civic ek4.
This is good or bad for aerodynamic and highway fuel economy? or no difference?
With rear lip:
Without rear lip:
[IMG] [/IMG]
03-02-2014, 11:43 AM
Polymorphic Modder
They added one to the Hybrid for Eco reasons. However the Hybrid did not come as a hatchback. So your car tail may not be long enough to make use of a small lip. But it is worth a try.
03-02-2014, 12:10 PM
It probably couldn't hurt. May help marginally. Looks cool anyways
03-02-2014, 12:15 PM
herp derp Apprentice
I was thinking of the lip on top of the trunk lid when I saw the title, but I thought this was about the bottom of the rear bumper.
I would leave it off myself
The Following User Says Thank You to 2000mc For This Useful Post:
03-02-2014, 12:56 PM
it may have some effect, i can see the lip takes on the same similar shape as modern day rear defusser, id keep it on,,
03-02-2014, 01:28 PM
Lots of Questions
Wouldn't that lip have a parachute effect, especially with no belly pan?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following User Says Thank You to jeff88 For This Useful Post:
03-02-2014, 02:31 PM
The lip is OEM Honda, but was designed for the civic ek9 (type-r), which has the same chassis as mine.
The fit is perfect but i do not know the reasons why it was designed for the ek9(type-r)
I have read something of the "parachute effect" in the rear bumper, but I don't know if with the lip works better or worse.
03-02-2014, 02:45 PM
it looks like the center section might not stick down much more than where the bumper is already. where its lower on the outer edges, it might have a little boat-tailing affect behind the tires, however it continues inboard too far for that purpose. where i think you would get some of the parachute affect.
for efficiency, id say no
if you think it looks awesome and makes you happy, do it. i doubt you would notice the loss in mileage if any
03-02-2014, 03:02 PM
#9 (permalink)
PSmodder lurker
03-04-2014, 05:21 PM
#10 (permalink)
The lip will give the air a clean edge to depart from, less parasitic drag and clinging.
