12-18-2013, 10:13 PM
reverse trike, low, recumbent, 80-250cc (anyone else made one besides hyperrocket?)
There have been a few threads in the past, but no-one seems to have completed such a project (other than the Hyperrocket made by an auto engineer). Does anyone have an idea why?
I'm thinking of mating the rear 2/3 of a scooter with the front of an ATV . . .
It seems reasonable, and could be very fuel efficient transportation - a bit like the Elio, but a good bit smaller (maybe 96" length, less than 36" height, much lighter, etc., but still passenger possible).
Any thoughts are welcome.
Scot
12-19-2013, 03:53 PM
I just learned that, for 3 or 4 wheel vehicles, in Washington State at least, "the vehicle must meet federal requirements and be certified by the manufacturer to meet those standards". So a home made scooter to trike conversion is problematic at best. If anyone has information about dealing with this, please share. Thanks, Scot
12-19-2013, 05:26 PM
My assumption is that as long as you don't alter the frame, your good. If you do you have to jump through some hoops. And you probably need someone certified in making or welding frames to do that work.
I try to be helpful. I'm not an expert.
12-19-2013, 06:00 PM
Certainly converting a scooter to trike involves changing the frame. There is also a concern about the ATV front end parts not being certified for road use (as opposed to off-road). I'm working on getting info from the state on the "hoops" and how to get through them . . .
12-19-2013, 06:05 PM
IIRC someone from Wa posted about their homebuilt trike; they went to a VW front end because the ATV a-arms weren't certified for road use. But if you called them scratch built they'd probably be OK.
12-19-2013, 06:31 PM
I've thought of swing arm suspension (VW), but expect it would be heavier than I need as the car was much heavier, while the ATV would be very similar, and I think the whole front end (wheels, brakes, suspension, and most of the steering system) could be used with little or no modification - cheap, easy and light!
Does anyone have ideas/experience with the issue of wheels/tires - using an ATV front end seems to push one into wide tires. I'd prefer to use small scooter tires (around 3", probably on a 10 inch wheel). The Yamaha Warrior 350 ATV front end that is available to me uses a 4 hole wheel. I wonder if it's possible to buy narrower wheels that would fit the ATV front end and be compatible with the 3" scooter tires?
12-20-2013, 04:54 PM
reverse trike
Have you seen Doug Malewicki's (sp?)1980 'California Commuter' ?
12-20-2013, 05:54 PM
I had not seen the California Commuter. Very interesting! Thanks!
12-20-2013, 06:13 PM
#9 (permalink)
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following User Says Thank You to HydroJim For This Useful Post:
12-20-2013, 06:26 PM
#10 (permalink)
Can you tell me where to learn more about the 3 vehicles pictured?
I really like the middle pictured one, though what I want doesn't need the big tires; I'd rather have small scooter wheels/tires.
Is it possible to purchase off-shelf suspension/steering/brakes/etc. parts? Or does it all have to be custom made?
