Old 08-23-2013, 01:48 PM   #1 (permalink)
SilverVan - '13 Dodge Grand Caravan SXT+
Team Dodge
90 day: 17.6 mpg (US)
Question ScanGauge : which gauges you choose?
I have a ScanGauge II, about 6 years old. I will have it's firmware updated soon and I was wondering: which gauges do you usually put on display.
Currently, I have LHK and LPH permanently displayed. For the other two, sometimes it's average fuel economy (current trip), sometimes Engine load or TPS.
I'd like to know which gauges you watch and the reason behind the choice to try to help me choose good gauges to better my efficiency!
Thanks!
Old 08-23-2013, 01:54 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Welcome Jack!
Don't forget to raise your psi also.
did you try a search. several threads on this topic.
Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - Search Results
also the first link in my signature
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Jack-MTL (08-23-2013)
Old 08-23-2013, 02:09 PM   #3 (permalink)
Team Dodge
Thanks for the quick reply and the very interesting thread you suggested! I'll raise my PSI as soon as I go to a gasstation that isn't charging 1$ for air, propably this weekend.
Old 08-23-2013, 02:54 PM   #4 (permalink)
mcrews's Avatar
I bought a small compressor at a discount store "big lots' in the states.
also Harbor Freight has them.
ECO MODS PERFORMED:
First: ScangaugeII
101Volts (08-23-2013)
Old 08-23-2013, 06:04 PM   #5 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
LOD - Whatever driving style you prefer, monitoring engine load is important. I have learned to control the amount of engine load up hills to limit wasting gas. For example, keep a lower engine load up a hill and allow speed to taper off, rather than hold speed the entire way up.
VLT - I display battery voltage primary because I plan to implement my alternator delete project soon, and will need to monitor the charge to not damage the battery.
MPG - Instant MPG is helpful just to gauge how you are driving. Instant MPG is not as instant as LOD, so I usually use LOD to control how much throttle I apply. But MPG is helpful when you want to know how current conditions are directly effecting MPG.
LB - I have entered this xGauge to monitor the primary o2 sensor reading. This is useful on lean burn engines because it will tell you when lean burn is engaged. It's not useful for non lean burn cars.
1998 Honda Civic HX - My Project Thread
The Following User Says Thank You to cbaber For This Useful Post:
Old 08-23-2013, 06:12 PM   #6 (permalink)
Team Dodge
That's not really doable for me as I live in a third floor appartment and I wouldn't have any place to store it.
As soon as I buy a house, I'll buy my own for sure!
cbaber, LOD is a good idea, my van doesn't do lean burn, but it does DFCO and I see it on the LPH setting when it drop to 0.00.
The Following User Says Thank You to Jack-MTL For This Useful Post:
Old 08-23-2013, 06:25 PM   #7 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Top Left: Instant MPG Top Right: GPH
Bottom Left: AVG MPG Bottom Right: IGN/LOD
That's how I have it today. I recently started using the GPH gauge.
*Note - IGn/LOD meaning that I might have it at one or the other.
The Following User Says Thank You to 101Volts For This Useful Post:
Old 08-23-2013, 07:36 PM   #8 (permalink)
I don't know what mcrews was referring to but you can buy adequate compressors suitable for inflating tires that will fit in a shoe box. They run off 12V so you can use the cigarette lighter/accessory plug in the car or clamp onto the battery posts.
They do draw quite a lot of current, (mine draws 20A) so consider that if your battery is old or marginal or the accessory plug is rated at less than that. Most aren't.
Avoid the really cheap -like ~$20 - compressors as they are noisy and slow to inflate the tire. The ones I'm describing have a die cast cylinder and fairly substantial construction.
Re. Scan Gauge display:
Instantaneous MPG
Current trip MPG
MAP
Coolant temp..
The MAP is the most useful in allowing driving with the right amount of engine load. (LOD isn't as easy to interpret for me.) Instantaneous MPG is not really useful, except for when coasting, where it gives an indication of open loop operation (0 MPG) and consumption vs coast speed while idle coasting, but is interesting. Current trip MPG tells me how I'm doing and my car doesn't have a coolant temp. gauge.
The Following 2 Users Say Thank You to Occasionally6 For This Useful Post:
101Volts (08-24-2013), Jack-MTL (08-23-2013)
Old 08-23-2013, 09:02 PM   #9 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
-Engine loading (LOD)
-Throttle position sensor (TPS)
-Water temperature (°cWT)
-12v Battery voltage (VLT) / Engine RPM / Intake air temperature (°cIA)
I wish TPS and LOD had decimals...
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
The Following User Says Thank You to HyperMileQC For This Useful Post:
Old 08-23-2013, 11:28 PM   #10 (permalink)
mcrews's Avatar
No,a little small one that plug int your lighter. About 15-20 dollars.
ECO MODS PERFORMED:
First: ScangaugeII
