Old 03-13-2023, 10:49 AM   #31 (permalink)
I don't dispute a single point you made. That being said, I believe I can improve my chances of maybe getting lucky first by some rudimentary testing by mocking up a controlled suction panel for one side (1/2)of the roof, use two switchable fans, (so I can double the air flow over originally considered to judge that effect) fabricate a full height (24"?) wool tuff vertical tree near the rear location of intended wing, rig up my Go pro for documentation, and make some 80mph runs to see if indeed I can vary the air stream, how much I can vary it, and where the laminar and turbulent interact at that location. All hopefully for less than a $1000 bucks. I probably would first need to spend some time optimizing my suction test mock-up panel, in regard to number of holes, spacing, diameter, angle etc, before I move to the tree wool tuff testing. I'm retired, I got time God willing, but money always runs out at some point.
Even if the suction trick completely fails, I'll have a better understanding of the useful location for wing mounting height in the end I believe,
The Following User Says Thank You to j-c-c For This Useful Post:
aerohead (03-13-2023)
Old 03-18-2023, 05:29 AM   #32 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Mercedes Benz Vision EQXX's approach...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (03-20-2023)
Old 03-20-2023, 10:49 AM   #33 (permalink)
maybe getting lucky'
I posted a new thread on the 2024 Ferrari SF90 Stradale aerodynamics which might be of use. Take advantage of the $millions they spent on CFD and wind tunnel time.
Do Rear Spoilers / Wings Help Any? Jammer Aerodynamics 27 12-30-2021 10:56 AM
Beetle Inspired Aerodynamic Thoughts ChazInMT Aerodynamics 43 12-19-2010 05:18 PM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-30-2010 11:21 PM
Cougar shape? Christ Aerodynamics 40 10-24-2009 06:27 PM
Shape Shifting EV Tourigjm The Lounge 0 02-18-2009 08:51 PM
