11-08-2015, 05:41 AM
#21 (permalink)
Focus - '05 Ford Focus tdci Futura
This is my upper grillblock. I.ve made it from 5mm scrap alluminum. I fits nicely and run it trough the heatwaves. Only in standing traffic the fan comes on to cool it down again and turning off. Only to slowly warm up over a 40 50 sseconds time.
The Following 4 Users Say Thank You to NickelB NL For This Useful Post:
11-08-2015, 11:24 AM
#22 (permalink)
Originally Posted by ksa8907
I do know that there is some worry about the longevity of the turbocharger when engine off coasting, if there is not adequate time for it to cool down after a period of high usage.
Looks like I have nothing to worry about then. I wont be doing any EOC'ing as Champagne is an automatic
11-08-2015, 12:11 PM
#23 (permalink)
Brandon Mods,
How about trying spark plugs that are a couple of ranges cooler? That shoud reduce cylinder/piston temp some.
11-11-2015, 02:06 PM
#24 (permalink)
EcoModding flying lizard
Here is my grille block  Didn't do any testing, but I haven't seen a difference yet, not even in warm-up times.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
The Following 2 Users Say Thank You to Daschicken For This Useful Post:
11-11-2015, 06:10 PM
#25 (permalink)
Originally Posted by MobilOne
Brandon Mods,
How about trying spark plugs that are a couple of ranges cooler? That should reduce cylinder/piston temp some.
"Cooler" and "hotter" spark plugs refer to how easily they can dissipate heat back into the cylinder head. Not likely to make any discernible difference.
11-11-2015, 09:02 PM
#26 (permalink)
Wannabe hyper..., miler !
Hotter or cooler plug TIPS create hotter/faster spark or cooler/slower depending on combustion chamber design.
Example: 2 stroke or Wankel engines
11-11-2015, 10:29 PM
#27 (permalink)
That honestly makes zero sense. You would never want a "cooler/slower" spark. The ecu controls the ignition timing, not the plug.
NGK Spark Plugs
11-11-2015, 10:57 PM
#28 (permalink)
HAHAHAHA, you must be a "young one"...
BEFORE anything that resembled computers, spark(timing) was THE manner to adjust.
Yes, distributors were what organized the electric discharge but final say-so was THE plug and ITS heat range...
The Following User Says Thank You to bikeprof For This Useful Post:
11-12-2015, 12:57 AM
#29 (permalink)
Moderator
Some factory grill blocks:
The Following 4 Users Say Thank You to Vman455 For This Useful Post:
11-12-2015, 05:22 AM
#30 (permalink)
Ultimate Fail
Thanks Vman. My neighbor has one of those Kias, and i noticed the block.
Some models of that same vehicle have them, while others do not.
( I think his has an 'eco' emblem on the back )
I had never seen the MB grille block before. I thought perhaps it was a European version, but i see the Illinois plates.
I'm reminded of a comment about ecomodding from another forum some years ago. It was something like " Stupid hypermilers ! If this #@!* really worked, automakers would have been doing it already. "
The Following User Says Thank You to Cd For This Useful Post:
