Old 05-01-2022, 08:59 PM   #41 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
tried to test a few different small mirrors on the inside of the car door near the window. NOPE! too many reflections from the inside of the window tint makes visibility bad, plus you get half of the inside door in the view. i will def need to go the route of fabrication a little arm and mount for those blind spot mirrors i showed pics of earlier and will have tp be installed outside the car
The Following User Says Thank You to Phase For This Useful Post:
aerohead (05-02-2022)
Old 05-02-2022, 12:30 AM   #42 (permalink)
Nowadays that most cars have curved glasses, which lead to more distortions to the image in the mirrors, I wouldn't expect it to be so great to use interior mirrors instead of regular exterior mirrors. Maybe it's time for you to take a look at those sports motorcycle mirrors which already have some aerodynamic housing and stalks.
Old 05-11-2022, 12:30 PM   #43 (permalink)
Phase's Avatar
Update. Finally was a dry night and spend an hour and a half doing the mirror versus no mirror test close to midnight
25 mile stretch round trip all interstate
47 degrees outwide and cruise control set to 65 mph
First test with mirrors,
51.8mpg average
Both mirrors completely off
53.8mpg
2 Mpg gain!
The Following 2 Users Say Thank You to Phase For This Useful Post:
aerohead (05-12-2022), freebeard (05-11-2022)
Old 06-22-2022, 06:06 PM   #44 (permalink)
Phase's Avatar
So these are the super mini side mirrors I fabricated. Very sturdy. Actually work really well. Only issue is clearly the part facing the wind is blunt and flat. I need to make some type of curved aero cover. Anyone have advice? I was going to use half side of tooth brush travel holders but they are kind of difficult to mount. Other idea was get black styrofoam and just whittle and shave it down into an aero shape then 3m sticky or gorilla glue it on
Any ideas would be helpful
Also they generate a lot of wind noise, so I’ll be trying a few vortex generators too later on
ID:	32437   Click image for larger version
aerohead (06-23-2022)
Old 06-23-2022, 11:16 AM   #45 (permalink)
ideas
Foam is good idea, it can be glassed over to create a permanent fairing.
Creating an 'armature' and laying up papier mache to create a slightly undersized form which can be fiber-glassed would also work. Once it's glassed, submerge it in water to disintegrate the form leaving only the shell.
Same for drywall compound over a hardware-cloth or expanded metal lath armature, ditto. I've done both.
Old 06-23-2022, 12:46 PM   #46 (permalink)
3D print with a 20% infill.
You can't be wise and in love at the same time. -- Bob Dylan
Old 06-23-2022, 01:31 PM   #47 (permalink)
print
Which raises the question of the computer, CAD-CAM software needed to create the data-cloud, actually 'drawing', and access to the printer which would recognize the cloud.
For every iteration.
Old 06-23-2022, 03:43 PM   #48 (permalink)
Left and right?
Forum members have been 3D printing parts since 2014. ecomodder.com/forum/showthread.php/im-making-custom-car-parts-3d-printer-30670l
My Ender3 bed needs leveling.
Old 06-23-2022, 04:01 PM   #49 (permalink)
iteration
Left and right?
Since nothing exists yet, we'd have to manufacture something just to test.
If not satisfied with the initial design, the entire process must be repeated.
We have a 3D printing lab at the local public library.
The kids design something at school, then bring the 'file' to the library where it can be 'manufactured.'
I have no idea what a 3D laser scan of the mating surfaces of the mirror chassis entails, from which each iteration of the mirror housing would share.
Rick Dale of Rick's Restorations would be happy to take $124/hour to create for us, in 2016 Dollars? As many times as we like.
I've never done it. Unlikely that I ever will. Any way I look at it, it looks like bankruptcy.
I presume that, creating a mirror-image for the other side of the car is a matter of a few keystrokes. Don't know.
Old 06-23-2022, 04:47 PM   #50 (permalink)
Phase -- It's hard [for me] to tell, is the stalk just a piece of all-thread? Can you adjust it?
I can imagine adding the sculpted foam former, then vacuum-forming a shell over it. Instead of removing it, just trim the edge. If there is an undercut, it would act like a crimped edge.
