Old 02-14-2010, 09:36 PM   #21 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Another interesting shape is logged today.
This is the second time this winter that this shape has appeared on the car, and this time a picture was taken before it melted and fell off.
The first picture shows a very interesting taper from the front tire, and is about the shape of something that I would expect to see from wind forces alone.
The second image shows just how "narrow" the front edge of the ice really is, and this surprised me a little bit.
Although this "pointy" shape has been seen before, it has not been on a car, but on the leading edge of the Yamaha TZ750 road racer fairing at Daytona in 1977. The leading edge of the fairing looked almost exactly the same. Yamaha must have done some wind tunnel testing on that old fairing.
This shape may make an excellent example of how to do this in foam/fiberglass when the time comes.
Jim.
ID:	5605   Click image for larger version
ID:	5606   Click image for larger version
The Following 4 Users Say Thank You to 3-Wheeler For This Useful Post:
cfg83 (04-14-2012), Christ (02-15-2010), mikeyjd (03-17-2015), MrMiata (11-15-2010)
Old 02-15-2010, 12:51 AM   #22 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Jim -
Is there any way that the tire could have carved in that narrow shape? It looks pretty close, turning the steering may have cut into the shape that was originally there.
Old 02-15-2010, 04:25 AM   #23 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
I see the same shapes on my car, and I hope to someday be able to make a pair of wheel farings in that shape.
Also for the rear wheels. As it is shaped by the wind, I belive it's the optimum shape for at leat your car.
Suspect I will be a slightly different shape from car to car - so go and take photograps of those Ice cones on different cars.
Old 02-15-2010, 12:18 PM   #24 (permalink)
90 day: 51.82 mpg (US)
You know you're an EcoModder when "snuds" are fascinating (name I've heard for the snow/mud things that build up behind the tires).
Old 02-15-2010, 12:22 PM   #25 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
EcoSnudder??
Old 02-15-2010, 09:18 PM   #26 (permalink)
3-Wheeler's Avatar
Originally Posted by Christ View Post
Jim -
I suppose it's possible that the tire would rub on the "sculpture" when turning, but certainly not when going straight forward.
There is almost the same gap between the tire and snow, as the normal wheel well has, and even when the wheel is turned, there are several inches of a gap to the liner.
As far as the back tire, the skirt prevented me from getting a good look, but substantial snow did accumulate in the cavity, and caused some noises when the car was first moving this morning. I sounded like something had broken loose under there until stopping to check things out.
Jim.
Old 02-16-2010, 04:56 PM   #27 (permalink)
Jim.
Two more data points
Old 02-16-2010, 07:07 PM   #28 (permalink)
Wow, tires kick **** up and it sticks. May wonders never cease?
Old 02-16-2010, 09:17 PM   #29 (permalink)
3-Wheeler's Avatar
It seems that Yamaha must have also kicked up some dodo, to come up with exactly the same shape back in 1976.
Maybe the bike ran off course, almost high-sided, ran through a cow-pie, came back on course, finished the race, and the crew chief Kel Carrithers came up to Kenny Roberts and said...
Holly crap Kenny, look at that work of art, right behind the front tire!!
Of course, the very next year at Daytona, guess what showed up as their latest "improvement" to the fairing, but a sculpture of dodo attached to leading portion of the fairing, and painted bumble-bee yellow to match the rest of the fairing. No need for foam and fiberglass here. Why not stick with the real thing.
It must have done *something*, because Kenny won the 200 miler that same day!! Was it crap that gave him the advantage? We'll never know.
Wonders never did cease, even back on that fateful day in 1976!!
Jim.
Old 02-16-2010, 09:52 PM   #30 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
My type of luck, I'd carefully craft something like that shape, go drive in cold slushy weather, they'd get covered in a thin layer of "Snud", and some dam kid would walk up and try to kick them off!
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Group Purchase of Aerodynamic Modeling Program windrider919 Aerodynamics 16 09-10-2009 07:02 PM
Modern Rolls Royce Phantom vs Aerodynamic Coupe Unheard Aerodynamics 2 06-19-2009 10:19 PM
