08-28-2017, 04:05 PM
Sono Sion - Solar Assisted EV
The Following 5 Users Say Thank You to NeilBlanchard For This Useful Post:
08-29-2017, 12:12 AM
It could probably collect a few KwH per day.
08-29-2017, 03:23 AM
https://www.sonomotors.com/sion.html
80kw motor. Doesn't say how much it weighs. Up to 30km a day via solar power.
08-29-2017, 05:51 AM
That sounds about right but pretty optimistic.
08-29-2017, 10:40 AM
I am not sure how a polycarbonate car body would behave in a collision!
08-29-2017, 11:30 AM
Thalmaturge
Why did they waste solar panels on the sides? Or is that just an applique to make the car look cooler?
08-29-2017, 12:12 PM
When the sun is low, the cells on one of the sides produce some power. When the sun is higher in the sky, the cells on the roof and hood produce power.
09-02-2017, 02:10 PM
If the cells are light and cheap, why not?
I like the shape.
09-02-2017, 02:13 PM
#9 (permalink)
Thalmaturge
Because they do add weight and are not cheap?
No way they're getting more than 5-10% of those cells' ideal output any given day. For the same cost, I bet they could get way more range by adding to the battery pack.
09-02-2017, 03:31 PM
#10 (permalink)
home of the odd vehicles
Each of those flex panels weigh under 4 lbs are up to 28% efficient and due to the design are more efficient at collecting indirect light than a standard poly panel.
This isn't 1999 anymore, a lot of foreign panels are getting to be very efficient at hobby prices .
