Old 12-15-2011, 11:38 AM   #21 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Thanks for the thread--it's reminded me again why I love my manual tranny!
In all seriousness, pretty neat experiment.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 12-15-2011, 12:38 PM   #22 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Originally Posted by Thymeclock View Post
Forget the aero mods. I tried, and it won't help. What we need is way of controlling the programming of the transmission to get it to do the TC lockup sooner.
If your brave you can make a TCC lock switch
Don't forget aeromods if you spend any significant time on the highway, they will help alot, just not in the city...
I also drive an atx and feel your pain in city driving. However, I can usually get 30+ in city. Improving my driving techinque has helped a lot.
Old 12-28-2011, 05:15 PM   #23 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Der AUTO BILD Verbrauchs-Test - autobild.de
Watch the pictures there are many measured fuel consumtion curves. I was not able to find picture adresses?
From curves you can see that your aero effects most to the fuel consumtion and the engine is the second biggest factor at those speeds.
My lupo 3L consumes 3l/100km @ 100 km/h speed .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 12-31-2011, 09:27 AM   #24 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I was surprised at Hägar's fuel consumption when stabilized at Vmax (187 km/h GPS).
It was less than 10L/100km - though it obviously takes a far higher fuel consumption to get there.
Climbing inclines at 130 kph rather than "eco"-speed (95-105 kph) also reduces fuel consumption in my car - the deal-killer is the acceleration of course.
At Vmax, the fuel consumption to go up comparable inclines hardly increased and was lower than while climbing at 105 kph, which tripled and quadrupled consumption to well beyond 12 L/100km.
Weird things seem to happen @ speed
Old 12-31-2011, 09:36 AM   #25 (permalink)
euromodder's Avatar
Can't grab the picture's URLs either, but you can grab the pages where the graphs are:
Was kostet Vollgas? - Bilder - autobild.de
Old 01-01-2012, 06:18 AM   #26 (permalink)
The PRC.
I get better instrumentation averages at higher speeds, but better tank to tank if the speed is kept low.
Maybe its something to do with the sample / calculation rate ?
Old 01-01-2012, 01:42 PM   #27 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
It is very unfortunate that widespread, easy to access engine ECU/ECM programmers don't exist that are plug and play and cheap to own like the scanguage.
If I could easily change the shift points in my autotragic and change its timing a tad without massive effort I would probably still own the buick lesabre.
I think maybe some more effort for easy to use DIY solutions on this front need to be made, if the auto makers won't do it, you should have the ability to do it yourself.
Having to desolder and socket the eeprom in the ECU, get a burner and figure out the code yourself, really isn't plug and play or easy.
Anyone want to figure out the AVEOs eeprom for shift points to help this guy get the most out of his car ?
Old 01-01-2012, 06:16 PM   #28 (permalink)
Climbing inclines at 130 kph rather than "eco"-speed (95-105 kph) also reduces fuel consumption in my car...
Interestingly I find something similar which I have always attributed to momentum keeping the vehicle moving and saving that fuel guzzling shift back one gear and unlocking the convertor.
At 95 kph I can drive to work on the freeway with no changes but at 85 kph the transmission shifts back , for the few hills there are , enough to move the revs up from around 1600 to about 2000.
This in turn is enough to move the fuel used up to around 8.0l / 100 (US 29 mpg) from the usual 7.3 (US 32 mpg) or so. A jump of about 10 % which is a reasonable amount.
Peter.
Old 01-03-2012, 01:44 PM   #29 (permalink)
Boltar - '19 Chevy Bolt LT
from the small amount of research I have done my sweet spot is 55 to 65, if I stick it in I can achieve 30 plus in my 1999 camry which is a feat in itself
Old 01-04-2012, 01:21 PM   #30 (permalink)
rmay635703's Avatar
My 010 cobalt gets the best FE between 25 & 45mph depending on conditions. P&G is different.
aveo, chevy, fuel economy, speed
