Old 11-11-2019, 09:25 AM   #181 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Honda Insight w/K24A2 (Acura TSX), 3.4 final drive and 0.647 6th gear. ~35F, sunny, roads were mostly dry, some damp spots from melting snow. A light breeze, mostly a crosswind. Car was fully warmed up. It was difficult to tell if I was on entirely level ground at times, but these numbers might be accurate to within 2-3mpg at worst.
40mph - 55mpg
50mph - 52mpg
65mph - 47.5mpg
75mph - 43.5mpg
Joggernot (06-05-2020)
Old 06-04-2020, 10:31 PM   #182 (permalink)
Cola - '20 Toyota Corolla LE
90 day: 54.26 mpg (US)
2020 Toyota Corolla LE 1.8L CVT speed vs. mpg plot
Hey y'all, here is the data that I have on my Cola.
I used a cheap OBDII adapter with the Car Scanner app for Android. This app is so awesome for endless customization of gauges and recording data. I've been spending many hours analyzing things like cruising speed vs. mpg (results posted here), optimal acceleration rates, and DFCO coasting deceleration rates.
The data here is imperfect because I did not adjust anything for wind direction, wind speed, or slope. However, it is a great starting point for understanding what Cola is capable of. The trendline that I used to fit the data is a 3rd degree polynomial for those interested. I will update it with a 2nd version whenever I get the chance to gather a lot more data.
(Btw, would someone let me know where it would be good to post other cool plots that I created?)
Name:	Speed vs. mpg.jpg
Old 04-07-2022, 01:34 AM   #183 (permalink)
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
Bone stock 2018 Mazda CX9 Grand Touring front wheel drive (the Grand Touring has 20" wheels vs 18" on the base) loaded with 500 lbs of people, pets & gear:
EPA rated 22/28 (28 mpg happens just below 70 mph actual suggesting an honest EPA rating)
I was surprised that the rate of mpg decline tapered off at higher speeds rather than plummeting downward given the exponential force of wind resistance. I made a spreadsheet & dug up the BSFC map for Mazda's 2.5L turbo and discovered that at 55-60mph the engine is operating well under that peak efficiency island but it moves closer as you approach autobahn speeds:
  • RPM is the calculated rpm to reach that speed in top gear (0.6) through the final drive (4.411) and the tires (30.0")
  • TE% is thermodynamic efficiency calculated from BSFC. The difference between 38% and 30.7% thermodynamic efficiency might not sound like much, but that 7.3% change works out to 19% higher fuel consumption.
  • BSFC is brake specific fuel consumption - the amount of fuel burned for a given amount of work. The lower the number, the less fuel required. Those numbers are estimated from the BSFC chart...
  • BMEP is brake mean effective pressure. It is a measure of the capacity to do work and was calculated from torque.
  • Torque was calculated from horsepower & rpm
  • Horsepower is the total power required to maintain steady speed
  • Dt & Acc HP is the estimated horsepower lost to the drivetrain & accessories. It is estimated at 20% based on a stock 250hp CX9 dynoing 200 hp at the wheels.
  • Aero HP is the horsepower required to overcome wind resistance at that speed
  • RR HP is the horsepower required to overcome rolling resistance at that speed
Even with California gasoline at $5.50/gal, the price of fuel is still too low to encourage people to slow down:
With California minimum wage at $15/hour, even a burger flipper's time is more valuable than the gas savings driving 55...
Calibration notes:
  • I set the cruise at indicated 55, 60, 65, 70, 75, & 80 mph, but based on timing mile markers at 60mph, the speedometer reads 1.5% high (so I adjusted all the speeds down 1.5% assuming the error is linear).
  • The odometer was dead on (trip meter read 20.0 as I passed the 20th mile marker - it flipped a bit early so it was probably 20.03-20.05).
  • Any error in the fuel consumption display is less than the 1%. I calculated 0.997, but that implies far more precision than available from the instruments at my disposal (gas station pumps are allowed to be off by 0.5% here)
  • I took the average of 2 directions (4-7 mph headwind one way and 4-7mph tailwind the other). Road is flat (gains 50 feet over 100 miles)
  • Air Conditioning off, windows up (fan on high venting fresh air)
  • 65-80* F external temperatures
  • No intentional drafting, but light freeway traffic provided some aerodynamic drafts/wakes
Also of note, I was unable to discern a difference in mpg filling up with E10 87 octane vs ethanol-free 91 octane from Costco. E10 has 3.3% less energy content and Mazda's computer on this 2.5L turbo will automatically increase power from 227 horsepower on regular to 250 horsepower on premium so it should be able to maximize timing. But any difference in mpg was overshadowed by noise from various random environmental factors.
Name:	Screenshot 2022-04-06 22.22.43.png
ID:	31871   Click image for larger version
Name:	Screenshot 2022-04-06 18.51.14.png
ID:	31872   Click image for larger version
Name:	Screenshot 2022-04-06 18.15.59.jpg
ID:	31873   Click image for larger version
ID:	31881   Click image for larger version
Name:	Screenshot 2022-04-08 14.29.28.png
Name:	Screenshot 2022-04-08 18.52.22.png
ID:	31883   Click image for larger version
Name:	Screenshot 2022-04-08 18.46.25.png
The Following 5 Users Say Thank You to Drifter For This Useful Post:
Ecky (04-07-2022), Eisberg (06-29-2024), Joggernot (04-07-2022), MeteorGray (04-12-2022), Piotrsko (04-07-2022)
Old 04-07-2022, 01:04 PM   #184 (permalink)
Joggernot's Avatar
Found this for the 2016 version of the 1.5 Turbo Honda Engine. Sweet spot is where I expected it, but max torque was lower than expected.
https://www.epa.gov/sites/default/fi...18-01-0319.pdf
The Following User Says Thank You to Joggernot For This Useful Post:
Ecky (04-07-2022)
The BSFC chart thread (post 'em if you got 'em) MetroMPG General Efficiency Discussion 302 05-03-2022 03:20 AM
EM Blog: GM engineers feel MPG gauges should be in all cars MetroMPG Instrumentation 2 10-24-2013 04:56 PM
2011 Ford Fiesta SFE (29 city / 40 hwy MPG US) Nels General Efficiency Discussion 68 11-29-2011 11:46 AM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
EM Sticker contest #2: guess Mom's MPG! ('97 Camry 4-cyl auto) ends Sun., Feb. 3 MetroMPG Hypermiling / EcoDriver's Ed 33 02-04-2008 09:30 PM
