Old 12-06-2012, 06:19 PM   #21 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
I wonder if it would do a wheelie.
- Tony
Old 12-06-2012, 08:39 PM   #22 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
Very perceptive of you! As time went by, that began to be one of my concerns. The Porsche transmission was about 1.5 inches longer than the VW tranny, so it put the engine's flywheel that much farther back. Then the 6 cylinder Corvair engine was longer than the VW engine, so that put the very back end of it even further back.
That's where I actually began to learn fiberglass construction/repair techniques, because I had to extend the back end 5 inches farther than "stock" so the engine would fit inside it.
Then to compound that, the Corvair engine was about 100 lbs. heavier than the VW engine. As I was rolling it around in my parents' back yard while working on it - without the front-mounted battery in it yet - I was almost able to lift the front wheels off the ground by hand.
So yes, I believe it would have been able to do a wheelie, and probably a LOT more easily than I would have wanted. With the battery in, and someone sitting in the seat, it would have been a little better, but I suspect it still would've been "too light in the front" for good handling.
Old 12-07-2012, 04:30 AM   #23 (permalink)
Even if you kept the front wheels on the ground, the handling in corners would be 'Tatra-like'.
Old 12-07-2012, 09:13 PM   #24 (permalink)
Team Suzuki
I don't know what "Tatra-like" is because I don't know much about Tatras, but if it means turning the front wheels wouldn't change your direction of travel under acceleration, then yeah, that's what I was fearing.
At this point, I don't even know what I'm gonna do with the thing. 30 years ago, getting it going was all I could think about & what I spent all my spare time on. Now I don't hardly even think about it, even though I see it whenever I look out the back window. I thought about trying to sell it, but I don't know if I could even get enough for it to make it worthwhile. In the meantime, the '66 Corsa engine is an antique, and at the rate I'm going, the whole thing will be! HAH!! Guess I should try to finish it & get it on the road, but just seem to lack the ambition. - so it goes -
Old 12-08-2012, 12:55 AM   #25 (permalink)
Tatra (company) - Wikipedia, the free encyclopedia
After the 1938 invasion of Czechoslovakia by Nazi Germany, Tatras continued in production, largely because Germans liked the cars. Many German officers met their deaths driving heavy, rear-engined Tatras faster around corners than they could handle. At the time, as an anecdote, Tatra became known as the 'Czech Secret Weapon' for the scores of officers who died behind the wheel; at one point official orders were issued forbidding German officers from driving Tatras.
Catastrophic oversteer, similar to when you back off the throttle in a corner with a fast Porsche.
Old 12-08-2012, 01:42 AM   #26 (permalink)
Team Suzuki
Oversteer or understeer? I always thought that if the car's nose didn't move sufficiently in response to the turning of the front wheels, that was "understeer". But if the thing tended to turn enough to make the rearend swing out, that was OVERSTEER. Do I have it backwards?
Old 12-08-2012, 02:41 AM   #27 (permalink)
No, you've got it right. But the mass in the back of the car would tend to make the back swing out in a corner, especially if the throttle were closed in the middle of it.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
freebeard (12-08-2012)
Old 12-08-2012, 02:56 AM   #28 (permalink)
Team Suzuki
Oh, ok. Guess I've never aggressively driven a tail-heavy car, so I wasn't familiar with the back coming out in a corner if you lift off the gas. I can see where it would "upset" the balance though, shifting more weight (and traction) to the front tires, while all that mass in the back is trying to go straight instead of following the path of the rear tires, which suddenly have less traction.
Old 12-08-2012, 04:45 AM   #29 (permalink)
It can come in handy when you're making U-turns.
But you have to touch the brakes to transfer weight to the front. I think it has to do with the mass of the car rotating around an imaginary line drawn through the roll center height at each axle. But I could be wrong.
Old 12-08-2012, 02:50 PM   #30 (permalink)
upset
I'm pretty certain that the fella who test drove my CRX was killed by what Freebeard refers to as catastrophic oversteer when the engine blew in a Mercedes he was testing while cornering at the Bridgestone/Firestone Proving Grounds.
If he had been in a 4-wheel power-drift at the time of the engine failure,he would have lost all chance of controlling the car.
What exactly is a "K" car? bennelson General Efficiency Discussion 34 11-30-2021 12:43 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
How do you get your car to warm up quickly? SVOboy EcoModding Central 65 01-08-2012 10:09 AM
DIY - Front Camber Kit SVOboy DIY / How-to 1 12-05-2008 12:52 PM
Diesel electric kit car, anyone? R. Q. Riley's latest takes shape (and looks good!) MetroMPG EcoModding Central 11 10-07-2008 02:52 PM
