Old 12-20-2010, 07:37 PM   #1 (permalink)
Suzuki DR200SE
I have just purchased a 2001 Suzuki DR200SE. Suzuki actually advertises this bike as being capable of 105mpg fuel economy. (your mileage may vary!)
After it stops raining, I am excited to get on the road and make some base line measurements to see what this machine can really do. It looks like a great prospect to actually record a triple digit mpg number.
There is some deferred maintenance to get done first so as to bring everything up to spec.
I am compiling a list of mods which I would like to try as well. If anyone has experience with this bike. Please let me know what you have already learned.
Thanks! RM
Old 12-20-2010, 09:22 PM   #2 (permalink)
greenjoe's Avatar
great bike to start with! The 105 seems optimistic as stock, but there's alot of cheap and easy mods to that bike to make it more streetable and eco.
Old 12-20-2010, 09:44 PM   #3 (permalink)
gil
gil's Avatar
The Drift - '85 Toyota Corolla GTS
90 day: 28.26 mpg (US)
!Rally - '02 Subaru Impreza WRX
90 day: 27.68 mpg (US)
Cinnamon - '13 Honda PCX 150
90 day: 75.86 mpg (US)
I was looking at that bike for ecomodding. Im interested in seen what you can do with it. Good luck.
gil
Old 12-21-2010, 06:30 AM   #4 (permalink)
NinFo - '09 kawasaki ninja 250R
good bike. i would say it will probably get between 85-90 with easy driving. 105 is pretty high, but you can hope.
Old 12-22-2010, 12:17 PM   #5 (permalink)
Toyota - '94 Toyota Pickup
90 day: 29.91 mpg (US)
Scooter - '06 Yamaha Majesty
90 day: 31.65 mpg (US)
Whoohoo! Have fun and good luck with it, GoSlow. Is it your first motorcycle?
Old 12-23-2010, 01:43 AM   #6 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.84 mpg (US)
I think 105 will be easily attainable. My Ninja 250 made 85, in short trips, in the winter.
Old 12-23-2010, 11:24 AM   #7 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Does it go fast enough to use on the interstate?
Nissan Versa Aeromods
Old 12-25-2010, 09:01 AM   #8 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
Thanks! RM
I had a 2005 DR200 that I liked a lot, but I sold it to get a WR250 Yamaha for a little more power and the ability to keep a higher average speed on 4 lane divided highways. the things i miss about the DR200 is the range of the 13L [3.4 Gal.] fuel tank, 78 mpg, 217 mile/2.78 gal. the other thing I miss is the low seat height. What I found with this bike was that on two lane roads and gravel roads this bike could keep up with anything that was keeping to the posted speed limit, 60 mph. I sometimes regret selling the bike. depending on what you expect from the bike, I would suggest that you start with some aeromods then go to a bigger front sprocket. look at Craig Vetter's web site, as well as some of the work done on this site. this bike has huge potential for very high FE.
Old 12-27-2010, 01:49 PM   #9 (permalink)
Here is an update on the DR200SE project. It has been almost constant rain since I brought it home, so I have not done much. I have made a few local rides to get acquainted with it's "personality".
It has good torque from right off idle and a smooth power delivery at low rpms. My technique for hypermiling is to shift up through the gears quickly keeping the rpms to a minimum. This motor seems well suited to this task suggesting very mild cam timing. I found some (unverified) cam specs online which would verify this. Here-
stock DR200 cam
_________lobe lift______valve lift____Duration at .050"
Intake____.245"________.320"_______204
Exhaust___.230"________.290"______ 200
I also ran a compression test and was surprised to record a 185 psi reading. I repeated the test two more times with the same results. My gauge is the kind that you press in to the spark plug hole as opposed to screw in. You could feel a good strong pressure which makes me think that these readings are accurate. I am very pleased about this.
I also pumped up the tires to spec, changed the oil using 10w30 petrol based oil and lubed the chain.
When the weather clears up I hope soon to have some baseline mpg data to report.
Old 10-23-2012, 12:22 PM   #10 (permalink)
Buggie - '01 Vw Beetle TDI Gls
I just bought a 2009 dr 200, brand new from a showroom for 3000 bucks. 1.2 km on the clock, found this old thread while searching info on what exactly I bought
