Old 06-14-2013, 12:25 AM   #31 (permalink)
Viscosity is what matters for mileage increasements.
Old 06-14-2013, 04:04 PM   #32 (permalink)
Unfortunately lower viscosity increases engine wear, at least in an engine which isn't designed for low viscosities.
http://ecomodder.com/forum/showthrea...els-25942.html
Old 06-14-2013, 10:05 PM   #33 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
I didn't put 0w20 oil in my diesel I was referring to my festiva in the previous post. my diesel has 10w30 mobile1 full synthetic.
Old 06-15-2013, 12:55 AM   #34 (permalink)
Sure. It's not for everyone.
Old 06-16-2013, 02:28 PM   #35 (permalink)
Jakins's Avatar
hX-TREME!!! - '97 Honda Civic HX
90 day: 54.75 mpg (US)
450sX-TREME!!! - '95 Nissan V8 240sx
chodercycle - '06 kawasaki ninja zx6r 636
i always put a little heavier oil in because in texas it so freaking hot and i have some leaks and i think i burn a little oil. like 10-30. should i just be using super light oil anyways? also i put some marvelous mystery oil in with oil change too. i think that makes it alot lighter.
Old 06-16-2013, 05:24 PM   #36 (permalink)
Jakins's Avatar
speaking of which. i put like 2/3 of a quart of marvelous mystery oil in on my last oil change. for the past 150K miles the oil has been black. now after this oil change it is crystal clear.
Old 06-16-2013, 07:23 PM   #37 (permalink)
90 day: 29.78 mpg (US)
How much oil is your car using? It's normal for cars to use some oil over time.
My old Subaru used a quart every 2000 miles from the day I got her at 119,000 miles. Oil use increased significantly when I used 10W 30, and decreased when I used 10W 40.
The higher viscosity will usually leak more slowly and protect the engine better, at the cost of a marginal amount of fuel economy.
Old 06-17-2013, 11:41 AM   #38 (permalink)
Jakins's Avatar
well at one point it seemed like it was going through a quart like every 500 miles. maybe im exaggerating. it was on a 2000 mile trip. but i fixed the distributor seal and cam seal and it helped alot! i see a bunch of oil at the bottom of the timing cover and im afraid it might be my front mail but i dont know. could just be all the oil that leaked down from the cam seal. also my vtec solenoid is leaking. but currently the oil leakage has slowed down alot! running 10/30 i think with the MMO which thins it out quite a bit.
Old 06-17-2013, 02:36 PM   #39 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Unless you are seeing below zero temps on a regular basis (like in the winter) you will not benefit in seeing higher fuel economy. I have run synthetic for most of my Corolla's life up until recently and experienced no change in fuel economy, in fact in the Corolla (switched 8000kms ago) I am seeing some of my best tanks yet and its no spring chicken.
If you had a turbo car or in the winter, I would run synthetic.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
motor oil, synthetic oil
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Low viscosity and/or synthetic gear oil? Dane-ger EcoModding Central 7 01-13-2008 07:58 AM
