Old 08-16-2011, 02:53 PM   #101 (permalink)
Originally Posted by TestDrive View Post
Two more views of the nose of the Nuna 4.
Looking at the frontal view of this vehicle, why are the wheel pants so wide? The tires and wheels on this vehicle have to be pretty narrow and light, it appears the wheel pants are much wider than they need to be which would create extra drag it would seem. If the center rear wheel is the steering wheel that would explain why it is so wide but if the front tires do not steer the vehicle why are the wheel pants so wide??
Anybody have a comment on that?
Old 08-16-2011, 06:05 PM   #102 (permalink)
WOW I completely missed this!!!!!!!!!!
Originally Posted by Blue Bomber Man View Post
Phil, do you think in a week or so I could get some critique from you regarding airflow on the design of my vehicle? I'm just finishing the subframe and will be begin to design the exterior body. I'm hoping to have the wheels fully enclosed within say 2-3 inches of the ground and have a good taper towards the rear across both axis (width and height) but I would love to get some insight from someone that knows much more then I on the subject.
Thanks!
Ben's Custom EV Blog
Blue Bomber,I'm just now catching your question.Sorry!
I tried to look at the links but they are inoperative.Please let me know how to link up with your project if isn't in the Smithsonian by now.
Really sorry!
Old 08-16-2011, 06:09 PM   #103 (permalink)
Wikipedia
Originally Posted by hypermiler01 View Post
I don't know if we can afford Wikipedia's 'free' information.They might want to research their topics a bit more.
Old 08-16-2011, 06:23 PM   #104 (permalink)
comment
This is my first look at the car.Would like to see what's underneath.It looks like overkill for everything underneath.There must be a 'mechanical' explanation.Those guys certainly understand Frontal area.
With engineering drawings we could look for area-ruling/Whitcomb-waisting/Coke-bottling/sectional density.
The upper and lower body camber may require these dimensions to prevent pressure spikes and suction peaks.Don't know.
Old 08-17-2011, 06:52 PM   #105 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I doubt they'd have rear wheel steering, which is fine for low speed forklifting but a bear to handle at high speed - these vehicles can hit 60mph / 100kph.
This is our contribution : Solarteam.be
What I wonder about is why they have the driver's bulge on top.
It reduces the area used for PV panels - which means compromising the bulge's shape as well in order not to make it take away too much area.
It increases the frontal area.
The driver is being baked under the harsh Ozzie sun.
I'd put the driver underneath the PV panel "wing".
More area for PV panels.
No shade on the panels.
No access over the panels / no tilting panels.
Less frontal area.
Thinner (ratio) wheel/driver pod.
Driver shielded from direct sunlight (in prone position)
The Following User Says Thank You to euromodder For This Useful Post:
orbywan (08-17-2011)
Old 08-17-2011, 06:57 PM   #106 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
This is the first car that came to mind when reading the first post. Look carefully at the mirrors, this car appears to drive rear end first from what we are used to. Wonder what the CD of this bad boy is...
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
Old 08-17-2011, 07:21 PM   #107 (permalink)
Less frontal area.
OK, looking at this photo I get it. The rear 'pants' are so wide because that is where the driver is, duh. And you're probably right about it not having rear steering, that would make it really sensitive to input.
That means the front wheels steer, which explains why the wheel pants are so wide, the wheels have to turn (a little in this case). Nevermind.
Old 08-17-2011, 07:25 PM   #108 (permalink)
euromodder's Avatar
What the rules say :
- minimum height for driver's eye is 700 mm above the road
- Each occupant must be provided with an appropriately constructed seat
consisting of a base (squab) and backrest.
- The angle of the (driver’s) seat must not be greater than 27°. Drivers must demonstrate the ability to sit, road ready (helmet on, hatch closed), with their back flush against the seating elements
Why the boots are so wide :
- The vehicle must be able to make a U-turn in either direction within a 16 m
lane (kerb to kerb).
aerohead (08-18-2011)
Old 08-17-2011, 10:59 PM   #109 (permalink)
For the super high mileage competitions, prone driver position is outlawed. Probably here too.
I'm sure they thought of pivoting boots. Question is why they didn't do it.
Old 08-18-2011, 06:05 PM   #110 (permalink)
Cd
It's almost an open-wheeled vehicle! The entire sides would be turbulence between the tire faces,certainly negating some of the 'positive' features.
Manly though,like a pop-up castration-mine.
Index of Phil Knox Aerodynamics Seminars & Mod-data lists TestDrive Aerodynamics 21 11-21-2022 09:57 AM
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 7 08-08-2012 06:00 PM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
