Old 10-04-2023, 07:00 AM   #1 (permalink)
90 day: 51.82 mpg (US)
Tested: rolling resistance of Dunlop Enasave vs. Bridgestone RE92 tires
OK! I FINALLY got around to doing this...
Within the past year or so, I happened to score both a set of nearly new Dunlop Enasaves on alloys AND a set of nearly new Bridgestone Potenza RE92's on steelies.
Both are 165/65R14 size, and are the OEM tires on the 2014-2024 (?) Mitsubishi Mirage and the 2000-2006 Honda Insight.
Coinkydink: I have owned a 2000 Insight and have owned a series of Mirages...
(Current car: 2014 Mirage 1.2L, 5-speed Canadian base model with no A/C. Curb weight under 2000 lbs! Thread: 3rd time lucky! Bought yet ANOTHER cheap, 3-cyl Mirage eco-appliance)
[ Thread: MetroMPG's Honda Insight boat tail extension (cardboard) tuft video; ABA test +9.7%... and ... Thread: Got a new UFO*: 2000 Honda Insight 5-speed (ailing IMA hybrid battery pack) ]
The RE92 is widely regarded in the Insight community as the best tire for MPG. (The Insight has very low aerodynamic drag, so reducing rolling resistance is a key consideration because it makes up a higher proportion of total drag than the average car. It helps the car enter & maintain lean burn at higher speeds.)
Long story short: in my simple coastdown test, both tires rolled almost identical distances.
Testing details:
-- Ambient temperature: 24 C / 75 F
-- Tire pressure: 55 PSI / 3.8 bar
-- Tread depth: Enasave = 5.6 mm / 0.22", RE92 = 5.1 mm / 0.20"
-- Tire + wheel weight same for both sets (both tires are 13 lb + 14 lb wheels)
-- Each set of tires got 4 coastdown runs, plus one last run after switching back to the first set.
-- All runs done back-to-back (same day, same conditions)
-- The testing area is 2 blocks from where the car was parked overnight, so tire temperature should have been extremely close for both sets (but not measured).
-- The car was positioned at the same point on a slight hill, then allowed to roll out to a level section, where the distance was marked on the pavement.
-- To minimize the potential of brake drag affecting the results, the car was stopped/positioned using only the handbrake rather than the hydraulic (foot) brakes.
Results:
-- The average coastdown distance was around 34.7 m / 112 ft.
-- The end points for all 9 runs were clustered within the last 122 cm / 48 inches!
-- 34.6 m / 113.6 ft ... Ensave average coastdown distance
-- 34.7 m / 113.7 ft ... RE92 average coastdown distance
Conclusion
How much faith would you put in this test? Enough to say that both tires appear to have similar rolling resistance? It sure seems that way to me.
If it's a valid & accurate test, then Insight owners should be happy to know the Enasave appears to be a viable alternative to the RE92 in terms of preserving MPG performance. (There are always fears in the Insight community that the RE92 is going to be discontinued. Although it was still available as of a year or 2 ago as far as I know.)
I'm not sure which tire costs more, but that would be a consideration for many people as well.
ID:	34215   Click image for larger version
The Following 9 Users Say Thank You to MetroMPG For This Useful Post:
Daox (10-07-2023), Ecky (10-04-2023), freebeard (10-04-2023), Gasoline Fumes (10-04-2023), Joggernot (10-05-2023), pgfpro (10-07-2023), Piwoslaw (10-08-2023), rmay635703 (10-04-2023), Vekke (10-04-2023)
Old 10-04-2023, 09:25 AM   #2 (permalink)
Only question I have is: what are the respective tread depths and tread widths
Old 10-04-2023, 11:10 AM   #3 (permalink)
Both sets have lots of tread - near max. I will measure and report back.
Will post a photo of the respective tread patterns too.
Old 10-04-2023, 11:49 AM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Look how the tire roundness is also near the edges and measure the contact patch width. If one is 10mm narrower it propably performs better at high speed...
To measure drive first on gravel road etc to get tires little dirty and then drive over A4 paper and measure that width from paper
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
MetroMPG (10-04-2023)
Old 10-04-2023, 12:58 PM   #5 (permalink)
Interesting. I have a set of 14" wheels with 4x100 to fit either of my Beetles. I didn't think 14s were a viable choice going forward. What's the rolling diameter?
You can't be wise and in love at the same time. -- Bob Dylan
Old 10-04-2023, 03:25 PM   #6 (permalink)
Having gone through the 14" rim size for my trailer replacement routine, you should note that they are going the way of the DODO for common availability. Still avail at chains on $pecial order
Old 10-04-2023, 03:57 PM   #7 (permalink)
Current Mirage tires?
The problem is they are slotted buggy mags, 6" and 8" widths. I could see a stanced Baja with low RR tires, the five speed and the Mileage Motor 1776. I've got those pieces.
edit: That might get the Beetle to 45MPG, just like the XFi or Dasher.
Old 10-04-2023, 09:16 PM   #8 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I've been missing your tests! I have a set of RE92 tires for my Insight, but out of laziness, I'm using 185/70-14s on steel wheels. They were cheap and local! Still good for 60 MPG without trying, and the extra ground clearance is nice.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
MetroMPG (10-07-2023)
Old 10-07-2023, 10:10 AM   #9 (permalink)
Great comparison IMO. Even if your testing isn't perfect, it does prove out that they are very close.
Old 10-07-2023, 02:28 PM   #10 (permalink)
Measured the tread depth... haven't looked at width yet.
Added to the first post:
- Enasave = 5.6 mm / 0.22"
- RE92 = 5.1 mm / 0.20"
