06-08-2013, 01:59 PM
#11 (permalink)
full tail
Originally Posted by Rango318
I've been wanting to build a full tail on my 94 eclipse basically right after i bought it. I really like the way Redneck made his recently and was going to base my build off his.
My only issue is, will it really help that much?
I mean, it seems like i see a lot of these done to cars that are not very aerodynamic in the rear, such as a metro, but the eclipse is a bit more angular off the rear window. I would love to see a 10% or so increase, but is it really possible with this car?
Any opinions or thoughts are much appreciated.
Also, what would most people recommend to use to build the frame of the tail? I do not access to many larger tools, so i will be doing this whole build with small hand tools and brute force.
A full tail would provide for a 28.3% mpg improvement at 55-mph,and 34% improvement at 70 mph.
06-09-2013, 02:08 AM
#12 (permalink)
That much? What is the most that anyone has achieved so far?
What could I expect for my Forester?
06-09-2013, 12:34 PM
#13 (permalink)
Originally Posted by Cd
Rango318, your car has a hatch that swings up.
It would be a simple thing to prop the hatch at the correct angle for good aero and run some tuft testing to see the results.
I know only the center section swings up, so you would have to fill the gap that is formed on the sides when you open the hatch glass.
( This would also keep you from getting carbon monoxide in the car during testing ! )
I'd love the see the before and after results of a tuft test of the car ( hatch closed and propped open at the correct aero angle.
That is a great idea just to test the idea. I had thought about using it as part of the tail, but not to use it to see if it would help. Thank. I think I will try it today.
Can i ask how you got those numbers? I love to do math and such and would really like to know how to calculate such a thing. I can only hope i get these numbers.
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
06-09-2013, 05:58 PM
#14 (permalink)
So, i did some testing today. Did a tuft test, which i will upload pics of tonight. I did one test with the hatch closed, then one with the hatch open, and all gaps sealed. I made it as close to the correct angle as possible. I then ran one tuft test. I decided to fill up, and drive to where i work and back to get a real life style test.
My tank last week, monday thru friday was a new high of 43.84.
To run my test, i did everything i would usually do when going to work. Stopped at the store, stopped in the parking lot at work.
The only things that i did not test for : usually the return trip is at night, so it is colder, engine is cold, and the headlights are on. All of which i did not include in this test.
All I can say about the results is WOW. I drove 58 miles on 1.091 gallons (53mpg). I am going to leave it like this for this week of work and see if i see this big of a change again. One can only hope.
06-09-2013, 11:49 PM
#15 (permalink)
So here are some of my pics from todays testing. I will try to have them in order, but if they are not, I hope you can figure it out. hatch down was first, then enclosed hatch up.
06-10-2013, 12:05 AM
#16 (permalink)
What am I doing wrong? I cannot see them!
06-10-2013, 10:30 AM
#17 (permalink)
Sorry. I tried to upload them last night but I believe the files may have been too large. I'm going to try to resize them and get them on again today
So I am having an issue uploading them and having them large enough that you can actually see them. How did you get the ones posted on the first page?
06-10-2013, 11:37 AM
#18 (permalink)
Ok. I think i got it.
yep
Ok. first 3 are before the hatch is up. Also the last one is as well. the rest are hatch up
The Following User Says Thank You to Rango318 For This Useful Post:
06-10-2013, 02:49 PM
#19 (permalink)
06-11-2013, 12:31 AM
#20 (permalink)
Thanks for the help Xist.
