Old 01-13-2011, 05:15 AM   #21 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by stovie View Post
Sorry i was trying to get to this conclusion but i was in a hurry. i was also just wondering if the bulg of the tread could have a pretty big factor in RR for example my dad has 31 inch tires with 1/4 inch bulg will i have 29's with 3/4 inch bulg both pairs are new?? Thanks agian
Let's start with how tires are tested for RR. All RR test procedures specify a load and inflation pressure for each test point. The standard test methods specify the load as a percent of the rated load and specify the inflation pressure based on the rated inflation pressure. Both of these are found in the load tables as published by the tire standardizing organizations.
Please note: The rated inflation pressure is NOT necessarily the sidewall inflation pressure - and this is particularly true for passenger car tires.
Some RR test procedures specify a single test condition, and some have multiple test conditions. The result is sometimes expressed as a single point and sometimes expressed as multiple points.
However, enough testing has been to be able to say that tires behave in similar ways regardless of the test procedure and the various test conditions - that is, the test procedures will give fairly good rank order when comparing different tires.
Needless to say, you can not compare different tires if the test procedures are different - without knowing more.
So if you want to know the difference in RR between your Dad's truck with 31"er's with a 1/4" bulge and your truck with 29"er's and a 3/4" bulge - well, that's not enough information.
Obviously a tire with a 1/4" bulge is more lightly loaded than the same tire with a 3/4" bulge - and by "more lightly loaded" I mean a percentage of the load at the inflation pressure being used. Notice that I am referencing both the load and the inflation pressure.
But your question involves different sized tires- and likely a different make/ model. If you've followed along, you would have seen that make/model has a HUGE effect on RR. There's also an effect caused by the difference in size.
So there are difference in tire size, load, inflation pressure, and make/model. Too much information to make an estimate.
The Following User Says Thank You to CapriRacer For This Useful Post:
stovie (01-13-2011)
Old 01-13-2011, 12:12 PM   #22 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
ok sorry for the miniscul info but the 31's are 80 psi Goodyear workhorse and are on a 8300 pound truck my 29's are 50 psi mesa A/P and on a 5300 pound jeep i tried to get info on there RR but couldn't find anything cause the browser would keep showing stuff that wasn't what i wanted or even what i was looking for. and i was referring to the tread bulging not the side wall
Old 01-24-2011, 10:32 PM   #23 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
Hmm, didn't exactly intend for this thread to last this long or become such a huge debate. Only real update here is that its winter, and we have mandated alcohol content in the fuel. Sucks. Current mileage is in the mid 18s. Still good considering its still mixed driving. Getting close to a new set of tires. And I really have to consider what I want. Giving a great deal of thought to moving to a 16" wheel so I can get a narrower tire. And that moves me into tires meant for trucks like F350 duallies.
When it comes to Heroes, RENEGADES are mine!
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Review: 2008 Chevy Malibu LT (31.3 MPG) RH77 General Efficiency Discussion 12 05-16-2009 09:07 AM
tire diameter guitarterry EcoModding Central 56 09-25-2008 01:57 AM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 03:59 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
