09-02-2010, 06:27 PM
#11 (permalink)
Originally Posted by silverinsight2
Any pictures or links please?
Here you go :
Found it on an RV forum of all places, where they were discussing the effects of a reverse teardrop shaped trailer on drag and FE, linking to a French site.
Apparently, it lowers the Insights Cd of 0.26 to 0.12 .
Note: they've also added front wheel covers in the picture.
The Following User Says Thank You to euromodder For This Useful Post:
09-02-2010, 09:13 PM
#12 (permalink)
That looks like a photoshop. Look at the outline of the door on the "trailer"
09-03-2010, 04:10 AM
#13 (permalink)
It could very well be PS .
There's also a line in the floor underneath the middle wheel.
There's no such line on the insight-only picture, though the light reflection spots are all in the same position.
There's a faint line in the floor, just aft of the mirror that also returns in both pictures.
09-03-2010, 05:51 PM
#14 (permalink)
image is not real
Originally Posted by euromodder
Here you go :
euromodder,sorry,that image is not real.
It's a cut and paste job I did from some materials I got in Japan from HONDA.You'll find it in the Phil Knox's Aero. Photos Album.
Some people have been posting it as something that exists.It IS the premise for my Full-Boat-Tail-Trailer -For-T-100-Pickup.
09-03-2010, 05:54 PM
#15 (permalink)
good eye!
Yep.not even PhotoShop,just Elmer's glue and Fiskars.
09-03-2010, 08:10 PM
#16 (permalink)
Do more with less
It would be pretty easy and cheap to use zote foam to fill in the gaps if you thought it necessary. I am surprised that no one here has worked with it.
Here is my biggest creation with it.
It is made from 1/2" thick foam with a minimal plastic/carbon/balsa frame. The chassis is a Catrike, Pocket.
Honda had an experimental trailer for their Insight 1 that continued the ideal aero shape further, leading to reduced aero drag.
They used flush but flexible panels to bridge the gap between towing vehicle and trailer.
– Noah Webster, 1787
09-04-2010, 10:11 AM
#17 (permalink)
Interesting stuff, as it seems to be very light.
Here's a description of how to use the stuff (when building a velomobile)
Builder John Tetz is even using thicker Zotefoam shaped as "angle iron" for internal bracing.
And a video of the end product :
09-04-2010, 10:15 AM
#18 (permalink)
Old skool deception, but it still works
09-04-2010, 02:44 PM
#19 (permalink)
Do more with less
John T is a friend of mine. I built my yellow fairing in an evening. I was going to make the bottom like his but didn't have enough material so I went with a ground effects type of design. It worked pretty well but it acted like a vacuum cleaner on the dust off the road. My lungs still protesting some today.
Zote wouldn't work well on a front fairing in an automotive application but it could be useful on trailing areas. It can be heat molded into 3D shapes.
