Old 01-28-2019, 06:42 PM   #11 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
This is probably a stupid question, but can one retrofit a cooling system to such a motor?
In model boats, people just wrap copper pipe around their motors. Despite the relatively small contact area, it's very effective. Could maybe add some conductive epoxy to help a little more.
Old 01-28-2019, 09:30 PM   #12 (permalink)
Yea, someone else mentioned something similar, but can that be done with the existing side glass in place?
In either case, large radius corners should help, but if true then why are the original Honda Insight and all versions of the Prius so sharp cornered?
Is the taper being equal top and side more important than a radius edge?
Does successful execution of one mean you do not need the other?
1. Modify the top curve to match the sides? I'd be more concerned about the drip rail than the quarter windows.
2-4. Excellent questions.
"We're deeply sorry." -- Pfizer
The Toecutter (01-29-2019)
Old 01-28-2019, 10:01 PM   #13 (permalink)
I'd look hard at a Bonneville-style spoiler before messing with that nice greenhouse.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
COcyclist (02-02-2019), The Toecutter (01-29-2019)
Old 01-29-2019, 02:50 AM   #14 (permalink)
In the GTI w12-650 example the black bubble top would be the existing top. The wing could spring off the rear fenders tops. It would be like the unholy offspring of a Dodge Charger Daytona and a Bertone BAT.
https://en.wikipedia.org/wiki/Alfa_Romeo_BAT
Frank Lee: sorry about the file size.
Old 01-29-2019, 05:43 AM   #15 (permalink)
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
That would actually look really good too.
I'm wondering how I would shape such a thing for it to actually be effective...
The Following User Says Thank You to The Toecutter For This Useful Post:
freebeard (01-29-2019)
Old 01-29-2019, 09:24 AM   #16 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Yep, I've seen setups that basically had a full sleeve around that had water flow through it, basically a water jacket. Never tried conductive epoxy before, but I suspect it might become a problem if he has to remove the motor for some reason, whereas the copper coils would be easy to remove.
Old 01-29-2019, 09:31 AM   #17 (permalink)
Maybe just salvage an old liquid cooled PC and coil a loop around the motor?
Building a Custom Water Cooling Gaming PC:
Step by Step 2018 Beginner's Guide
https://www.build-gaming-computers.c...ooling-pc.html
www.frozencpu.com has a bunch of different parts that could work for building a system.
Old 01-29-2019, 09:56 AM   #18 (permalink)
As I understand it the Bonneville style rear deck spoiler, it must fill out the aero-template shape (see small image attachment - bottom), and yet you still do not have the efficiencies of air attachment.
I agree that it is a shame to mess with the greenhouse, but do not see a way around it with such ambitious Cd goals.
Lowering his lofty aspirations is the only real alternative, isn't it?
Personally, I like the car the way it is and would not change it's looks. However, it's not my car.
NOTE:
Speaking of my own car, I studied a version of a raise Bonneville plane, it just happens to look like a wing but is not intended to act as one. This identity confusion may have prevented others from understanding my intent.
See attachments.
Perhaps such a device could be used on this Triumph.
NOT MY CAR:
https://ecomodder.com/forum/showthre...ler-34390.html
https://ecomodder.com/forum/showthre...e-36229-3.html
Image directly above is different designs to illustrate template fitting.
One might call the two images above that (using Sponge Bob) a raised platform Bonneville spoiler plane in lieu of the more traditional one seen on the Corvette (far above) that is simply an extension of the trunk plane with perhaps some winglets to contain or delay vortex swirls.
EDIT-2:
I found another thread were people were discussing similar concepts.
Flat Bonneville-type spoiler
https://ecomodder.com/forum/showthre...-14946-12.html
Once again these examples do not maintain constant air attachment and are considered less describable than full Kammbacks.
EDIT-3:
Same idea, just not done real pretty.
https://ecomodder.com/forum/showthre...ler-14946.html
A more graceful example.
https://ecomodder.com/forum/showthre...r-14946-4.html
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
aerohead (01-30-2019)
Old 01-29-2019, 10:03 PM   #19 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Because production cars are designed under a variety of constraints, like maximizing interior volume, achieving a certain minimum headroom, having adequate space for side curtain airbags, and doing all that while minimizing cost.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Old 01-29-2019, 10:35 PM   #20 (permalink)
That is part of it, but Volvo seems to of worked a little different formula so it certainly isn't mandated.
https://www.motortrend.com/cars/volvo/c30/2013/
Going back to the wing that isn't a wing idea I was exploring on the Porsche and evident on the Ford Escort RS, exactly how less effective is it than a Kammback?
https://topworldauto.com/cars/ford/f...otos.html#gp/5
https://topworldauto.com/cars/ford/f...tos.html#gp/32
https://topworldauto.com/cars/ford/f...tos.html#gp/33
https://topworldauto.com/cars/ford/f...tos.html#gp/35
Chin Spoiler:
Roof Wing
aerohead (01-30-2019), COcyclist (02-02-2019)
Hey, I'm here for the aeromods bomber991 Introductions 21 04-23-2010 01:00 PM
