Old 03-02-2009, 10:01 AM   #21 (permalink)
1984 Fiero Indy - '84 Pontiac Fieo Indy Pace Car
90 day: 17.38 mpg (US)
2011 ZX6R - '11 Kawasaki ZX6R
90 day: 33.82 mpg (US)
2005 CRV SE AWD - '05 Honda CRV SE AWD
90 day: 22.49 mpg (US)
2007 Corvette Coupe - '07 Chevrolet Corvette Coupe
90 day: 21.49 mpg (US)
This would be a good place to start some reading.
Welcome to locostusa.com • Index page
Old 03-02-2009, 01:12 PM   #22 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Bookmarked. Thanks!
Hopefully the interlibrary loan for my copy of "Racing and Sportscar Chassis Design" will arrive before I have to head out to NE on business next week...
-Terry
Old 03-26-2010, 07:14 PM   #23 (permalink)
BigWhiteWhale - '01 Ford F250 Lariat Crew Cab Superduty
YOu could find a retired dune buggy, and cut it modify it to your need. MIG is faster.
Old 03-26-2010, 07:16 PM   #24 (permalink)
Oh yeah and a lot of these are based on VW chassis.
Old 03-27-2010, 01:33 AM   #25 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
"Tube" frames subdivide into simple beam types, such as the AC Cobra, or the Locust. The Locost has a "space" frame, using a 3-D truss instead of a pair of main tubes with some cross-connection and various extensions. The space frame is far lighter for the same stiffness.
Frames are primarily built up for stiffness, not strength. Thus, mild steel is often just as suitable as 4130 aircraft tubing, titanium or aluminum. What it lacks in ultimate strength goes into useful toughness in a crash.
For a great overview of the options, see "Structures" by J.E. Gordon - it is very readable, and not expensive on eBay.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Tango Charlie (03-27-2010)
Old 11-28-2013, 11:59 AM   #26 (permalink)
Originally Posted by Tango Charlie View Post
If a guy would want to construct a tube frame chassis for a road vehicle, where could he get guidance for its design? I've looked on Amazon for books, I've googled, but haven't found much. There's books on suspensions and what not, but nothing really for the actual frame itself. One thing I have uncovered is Finite Element Analysis. I think the AutoCad Pro program can perform FEA. Is this what you need to calculate strength of a particular design? AutoCad Pro is darn expensive, though...
There are some great software for tube bending and design,some are free.I would not try to reinvent the wheel,look at what others do and build off it.I would not use anything less then 1026 DOM or 4130 steel,you can't go wrong with 1 inch or better,using 4130 you can reduce the thickness for weight saving's but 1026 will be more practical.Look to JD squared for some great ,affordable and safe bending tools.Be careful using cheap bender's,I'm thinking about buying the model 32,hydraulic bender,1000 plus dollars and you can make headers,exhaust,chassis,motorcycle frames etc.Excuse my writing,I just like to get to the point.good luck.
Old 11-29-2013, 08:51 PM   #27 (permalink)
For 4130 and other "chromoly" steels, you need to do a bunch of heat-normalization after welding. Mild steel, while heavier, is easier to work with.
This from several metal-workers and fabricators that I know.
-soD
Old 12-01-2013, 11:48 AM   #28 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
If you are going the tube frame route, you might look at composite tubing. There is "Pultruded" fiberglass tubing in many shapes, round, square, I-beam, flat, angle, etc., which can be stronger and lighter than steel or aluminum, plus no exotic welding skills are need to join the tubes.
The Following User Says Thank You to CFECO For This Useful Post:
jumper (04-27-2014)
Old 12-05-2013, 01:09 PM   #29 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
Fiberglass tubing
I just received a quote from a retailer who will sell small quantities of Fiberglass rectangular tubing. 40' of 2" x 4" for $869 including delivery, this is still too much. There is 184' of surplus 2" x 5" in Springfield Missouri for $225 but they will not ship.
Old 12-05-2013, 02:09 PM   #30 (permalink)
The joints of any space frame structure . . .
. . . are very critical. With metal tubing, it is a simple exercise of fit and welding or brazing. With brazing, gusset plates may be needed depending on loading.
Designing composite joints is even more complex as it is not a homogeneous structure that is transferring the loads. The joints in your structure could very well be the weak links in your car.
Winning entries in Infineon "Rev up fuel efficiency" design competition MetroMPG EcoModding Central 3 05-15-2011 02:24 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Aerofairing for a sport bike, Design and Creation dichotomous Motorcycles / Scooters 8 07-27-2009 07:19 PM
wheel airdam - deflector - strake? design questions lunarhighway Aerodynamics 14 04-02-2009 12:45 PM
