Old 11-09-2022, 03:58 PM   #1 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Two question on my active grill block?
So my Ioniq had active grill shutters for the main section. You can clear see them closed automatically since it’s winter time
But the lower section I circled in blue doesn’t have an active shutter system. It goes towards the radiator at the bottom. There are also little ramps of holes in the front under tray
My two segmented questions are-
Would I be helping or hurting aerodynamics but blocking off those lower holes? Everyone says grill blocks help aero, but what if Hyundai wanted some air to fly in and then go down thru the front under tray to help with something secret they discovered in the wind tunnel? What about stagnation points or adding higher pressure to that front grill lip area? Could that add drag? Or does it just seem like I’m over thinking and it’s making no difference?
The main reason I’m curious to blocking off that section is to limit air flow from going into the engine bay and radiator since it’s so cold now. My cars heat inside only works when the engine is fully warmed up. That or I’m freezing. The hybrid issue is every time I come to a stop light, the engine cuts off and switches to battery and I lose my heat pretty fast. Also hybrids take longer to warm up than most cars. Do I run any chance of overheating by blocking that area off and being a full 100 percent grill block? Should I leave it as is? I really want my engine to warm up faster and stay warm longer. If the engine gets too hot, the active shutters should open up right? I just feel like even with the active shutters closed, allowing cold winter air into the bay and lower radiator, even if it’s a small amount, is still hurting the warm up period. It also rains a lot here too so more water goes into the engine bay too with that lower opening.
ID:	33007   Click image for larger version
The Following User Says Thank You to Phase For This Useful Post:
Gasoline Fumes (11-09-2022)
Old 11-09-2022, 05:26 PM   #2 (permalink)
90 day: 29.78 mpg (US)
Every car I've seen has an upper and lower grill opening. I fully blocked both the top and bottom grill on my Prius in the winter. In the summer I'd open half the upper grill, but leave everything else blocked.
I had Torque monitoring coolant temperature to make sure I didn't run so hot that the fans came on. Only once had the fans turn on while climbing a mountain.
Old 11-09-2022, 05:45 PM   #3 (permalink)
Phase's Avatar
Ok I’ll probably block off the little lower opening. If it gets too hot the upper grill will open anyways ( that happened this summer driving thru Arizona mountains in black car)
I’m assuming no aero benefit though since it’s such a small area?
Old 11-09-2022, 06:14 PM   #4 (permalink)
I posted on this in another thread:
An extreme example
https://ecomodder.com/forum/attachme...p;d=1565844879
On a Toyota Supra
i.pinimg.com/originals/6c/1c/dc/6c1cdc8b320487a11334ff47c0141cb9.jpg
A splitter, same deal
http://trackdogracing.com/images/pro...splitter_d.jpg
I think the idea is a faster moving, unimpeded central jet draws air from around and between the tires. Just something I've seen. The other extreme is a small tab [or spat] in front of the tire.
Old 11-09-2022, 06:24 PM   #5 (permalink)
Phase's Avatar
so block the lower opening that doesnt have active shutters or not? its getting cold in oregon as you know lol
Old 11-09-2022, 08:20 PM   #6 (permalink)
Does it lead to the radiator or under the car?
A-B-A testing. Maybe 0.01-2 delta.
Old 11-09-2022, 10:32 PM   #7 (permalink)
Phase's Avatar
It goes straight ti the bottom part of the radiator. I guess to allow some slight airflow in the summer. The main shutters barely ever open. Even in summer in road trips they won’t open. They only
Open when it’s over 100 degrees and aggressive driving.
I put duct tape over the smaller opening And didn’t notice anything bad. I’m sure some air flow from the that vent into the lower skid plate area but I don’t think it affects anything
freebeard (11-09-2022)
Old 11-09-2022, 11:42 PM   #8 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
That's my old Civic Wagon. I had multiple holes for the license plate screws and would manually move the plate as required. It was usually as pictured most of the year just poking around at moderate speeds. If I took it on a higher speed trip, it needed more air. About half of a license plate (6" x 6") was usually enough. The splitter probably increased pressure at the opening, sending more air into it. It was fully blocked in winter. There really wasn't any useful upper grill opening. I don't think any air that made it through that upper slot would hit the radiator, but it's been a while since I looked at that poor car.
Hyundai might've left some grill always open in case the shutters fail to open. Just a guess.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
freebeard (11-10-2022), redpoint5 (11-10-2022)
Old 11-10-2022, 01:03 AM   #9 (permalink)
One of my favorites. Mainly the tire deflectors. Are those conveyor belt material?
Old 11-10-2022, 02:01 AM   #10 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Baler belting from Tractor Supply. They used to sell it in bulk by the foot.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
