Old 12-06-2019, 03:19 PM   #11 (permalink)
Tuners from edge, bullydog/sct wont make a noticeable improvement that pays itself off in any reasonable amount of time. Most Ford and Dodge diesels I owned with various types of ecm flashers and directly plugged in chips saw maybe a .5-1mpg barley on highway road trips.
You would see a steady 1.5mpg with a basic full bead tonneau cover though. You could also look into low rolling resistance tires/skinnier tires. For example I run a 285/75r16 but I am swapping to a 255/85r16 next set wich gives me 1.5in narrower tires and .5in taller. It wont be dramatic but wont look goofy and will help some.
Aeromods are going to be the biggest improvement and a basic full bed tonneau cover brings a steady 1.5mpg boost. it will payitself off super fast in 80 mile daily trips. Also drafting behind bigrigs if your commute has them. You don't have to be an an unsafe distance from them to gain a boost in economy. plus the slower speeds will help even more if time permits of course.
Old 12-06-2019, 03:40 PM   #12 (permalink)
Grogu - '12 Toyota Tacoma Base regular cab 4x4
90 day: 23.3 mpg (US)
My tires are 255 width. Low rolling resistance tires are usually garbage when you go off pavement or get in snow. I have a cap over my bed because I have that area set up for sleeping /my dogs.
Old 12-06-2019, 10:05 PM   #13 (permalink)
Make a removable air dam for the 9 to 11 months that aren't hunting season. That's what I did with my suburban, in the event of hunting season or deep now I have 3 bolts on each side that once removed release the air dam.
Go to highway tires and a set of snow chains. They will be the baddest mud tires you will ever use. No point in wearing out expensive, soft, quick to wear out muds with 99.9% highway miles. I used to buy aggressive mud tires back in the early 2000s, then switched to aggressive A/T tires for a little while then to highway tires and snow chains back in 2009.
The highway tires lasted 2 to 3x longer than the muds, were cheaper by a lot and rode better.
This year my friend put his set of muds on his truck for deer season, where he is the limit was 5. In an unusual chain of events he tagged out the first day. So I think he had his mud tires on for a total of 3 or 4 days. He has had the same mud tires since 2012 and they are still like new.
I have low rolling resistance tires on my Nissan leaf and it has snowed twice here so far for fall/winter 2019 and they did great. This "Winter" for west Texas and eastern new Mexico has been labeled as "extreme" by weather dot com.
The Following 3 Users Say Thank You to oil pan 4 For This Useful Post:
Ecky (12-07-2019), iikhod (12-07-2019), slowmover (12-08-2019)
Old 12-08-2019, 04:33 PM   #14 (permalink)
90 day: 19.36 mpg (US)
Four days of round-trip commute.
The real question is ANNUAL MILES
Of which:
1). What is annual average MPH?
2). What is annual fuel consumed?
That’s where answers are needed. Records.
Spending to save only works when one has exactitude.
320-miles of commute plus another forty for all errands, etc.
Call it 19,000-miles per year. Zero idle time.
1,188-gallons fuel.
Syracuse Average this week is $2.60. ($3088)
Ten years is $31,000
Economy is better understood as longevity plus reliability. A temp/humidity-controlled insulated garage benefits any vehicle choice.
Fuel mileage, like tire and brake life, are only indicators. Not central, but marginal.
Thus, past best storage (as all but a few hours are spent at rest), spending to save is with tire choice.
To get to small potatoes (like a tuner), investing in pre-heating engine oil & coolant is indicated next. Year-round. Cheaper still are grille blocks (upper only for mild; full for below 31F only (thermostat should never open prematurely due to reduced cooling).
The longer term is with shock absorbers (higher than base Bilstein or FOX; remote reservoir; need best control of body & springs); new cab & bed bushings; new tie rods; poly anti-roll bar bushings; etc.
Brakes should operate as new. No exception.
Steering requires ZERO play. Align for best wheel return plus lowest wear.
All maintenance time/miles intervals reduced 10% with nothing skipped.
New factory parts only. Never rebuilt.
All lamps replaced every three years maximum. New headlight housings if at all faded.
Rebuild the drivers seat.
This is how to spend to save: Storage. Pre-heat. Brakes, Tires, Steering as new.
Posture, vision, and control as new OR BETTER.
The number of times one changes from steady-state is first. Second (and where most fail) is the DEGREE & DURATION of driver input necessary. What’s necessary is emotional in effect (lazy Americans can’t distinguish desire from necessity), so exert discipline. Fewest. Shortest. And won’t be ever be at upper posted limit. It’ll be about never stopping or idling, first.
But before that: records of every gallon (FUELLY). Average MPH (engine hour meter).
The feedback needed en route is with an ULTRAGAUGE. Or, the old dashtop trio of engine vacuum, tachometer and fuel flow meter gauges.
Set cruise control at 58-mph for commute. Never more. Leave earlier. Arrive earlier and enjoy the empty moments acquired.
Get that AVERAGE MPH as high as possible. Should be NEXT TO NO DIFFERENCE between city and rural Interstate in MPG.
If my highway is 24 and city is 21, so can you (achieve close figures).
Cummins engineer DIESEL DAVE was the pickup MPG champ. 47+. That’s more than twice mine. But mine was 1.5-times the owner average. (How many engine starts per week? Record. How many accel/decel events per day? Record. How many non-work related trips per week? Record).
Dave did his by getting everything done in a warmed-up vehicle. That’s in excess of fifty miles summertime for tires to come to equalization.
It’s the operator. So long as the vehicle is far better than you can utilize, a magic rifle scope won’t give you 1-MOA at 400-yards. Jewel the bolt, bed the barrel, crown the muzzle, install a Geisselle trigger, fix the LOP. All operator problems for this analogy.
Still want to spend to save?
1). Plywood tonneau half the distance from tailgate to cab. Then on to cab roof wing.
2). Seal bed/cab gap. Seal gap between tires and body (see PETERBILT EPIQ 579). Convex wheel covers (see FLOW BELOW).
3). Research using expanded metal as bellypan. I’d try fabric over it as well.
The Following User Says Thank You to slowmover For This Useful Post:
iikhod (12-17-2019)
