View Poll Results: What to do?
Don't do it 1 14.29%
Hub Motor directly on the rim 0 0%
Hub Motor somewhere else 1 14.29%
Normal Motor "inboard" 0 0%
Something else 5 71.43%
Voters: 7. You may not vote on this poll
Old 09-12-2023, 12:17 AM   #21 (permalink)
Sure. Either this, or having to resort to oversized hub motors in order to reach the same performance figure.
Old 09-12-2023, 02:35 AM   #22 (permalink)
Simon TT's Avatar
BMW - '09 BMW E91 325d
90 day: 50.38 mpg (US)
SRCE - '04 Smart Roadster Coupe 60KW
Something to consider when choosing between hub motors and frame mounted motors is the very large difference in axle torque.
With a hub motor the rated torque is also the axle torque. With a frame mounted motor the motor torque is multiplied by the gear reduction ratio which is generally 3 to 5 times.
A 100 Nm hub motor puts 100 Nm to the rear axle. A 100 Nm mid-drive motor puts 300 to 500 Nm to the rear axle.
That is why bicycles and motorcycles with hub motors are generally much slower to accelerate than a vehicle with the same size frame mounted motor.
Sure, but since my ICE only has 110Nm and I don't want a full hybrid pretty much any motor should have enough torque
Old 09-12-2023, 10:45 AM   #23 (permalink)
Simon TT's Avatar
I just saw this video (YouTube: b Sport Valkyrie 3(I can't post links)) about the Aston Martin Valkyrie, it also uses an automated sequential manual transmission and an electric motor inside it wich does exactly what I had in mind: it is used for low speed driving, as reverse, to smooth the shifts, to start the engine and for recuperation.
I don't exact know the internals of my gearbox, but replacing the reverse gear with a motor should be possible, if not I could mount the motor externally
Old 09-12-2023, 11:05 AM   #24 (permalink)
Probably easier to get a transfer case used in 4wheel drive systems and add a motor to that. Plus you get an additional lower series of gears.
Old 09-12-2023, 11:39 AM   #25 (permalink)
Simon TT's Avatar
How do you want to place this? Gearbox-Transfer Case-Diff-Driveshafts? because the Diff is integrated into the gearbox. Gearbox-Diff-Transfer Case- Driveshafts seems very difficult
Old 09-12-2023, 09:01 PM   #26 (permalink)
I'm well aware of some replicas of the Lotus 7 fitted with motorcycle engines resorting to an auxiliary electric motor only to provide reversing, not being a hybrid at all. Maybe you could remove the reverse gear from the stock transmission of your car, which I wouldn't recommend, but I don't believe replacing it with an electric motor right inside the transmission case would be any easy.
Old 09-16-2023, 07:58 AM   #27 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Recently I bought a second EV, a BMW i3-REx, so I could work on my Tesla Model 3 when something might take more than a day:
  • 2017 BMW i3-REx
  • $15,000 (add taxes and fees)
  • 57,000 mi (battery warranty 60,000 mi or 8 years)
  • 27 kWh (28.3 kWh new)
  • Fixed gear, no transmission
  • 106 mi range at @65 mph
  • 88 mi range on mid-grade gas @65 mph
It is an EV around to and from the nearest towns with highway privileges, ~36 MPG. Cross country is like a motorcycle with stopping every ~1.5 hours to top off the 2.3 gallon tank and drain the used coffee. Enclosed, there is no helmet, bugs, rain, cold, or heat in a comfortable four seater.
It is very hard to retro-fit any kind of EV drive into an ICE car. The body structure is wrong and inserting a 'power assist' has no friendly power take-off or add-shaft interface. The alternator/motor systems have been a mess and you're adding parts that always reduces reliability.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 09-16-2023, 03:18 PM   #28 (permalink)
How often does the Tesla need work?
It depends. VW Beetle, Porshe 914, 356, 911 are popular choices.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
Old 09-16-2023, 06:37 PM   #29 (permalink)
Engineering first
Remember mine is over 4 years and 115,000 miles:
  • Windshield and roof glass from pebbles thrown up or dropped from trucks.
  • Passenger side wheel bearings from hitting curb.
  • Front bottom from parking curb scrapes.
  • Bottom rear cover from road debris
  • 12 V battery wore out.
  • OEM tires wore out
  • Added 2” receiver hitch
  • Unseen post while parking
  • One cabin filter replacement
  • Most frequent, window washing fluid
My cars work for me and most of these were wear and tear from working hard. My previous Prius had similar maintenance plus Spring/Fall oil changes, annual engine filter, two transmission oil drain and fill, failed attempt to replace brake booster after 260,000 miles.
An EV is a car body encapsulation of a near maintenance free electric drivetrain.
Bob Wilson
Old 12-31-2023, 10:07 PM   #30 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Keeping an eye for some wrecked Fiat or Jeep with a mild-hybrid version of that 3-cyl 1.0L GSE engine and swap it into your car could serve you quite well.
might as well go with GM's option a v8 engine 6.0L LS2 engine with it's in transmission EV motor..
it would still do 40-45mpg in a car..
the best i was able to do was 32mpg.. 100% stock
