Old 01-25-2025, 10:39 AM   #1 (permalink)
Ademonrower
Volvo 240 early series, headlight covers
The suggestion that someone on Ecomodder made that I should close off the openings around my headlights kept nagging at me, so I finally made headlight covers for better aerodynamics and headlight glass protection. Material: 4 mm Makrolon (polycarbonate), the stuff from which modern headlight glasses are made. Covering the heads on this model closes many gaps through which air can pass and cause drag. It also protects the ever more expensive glass 🙂 Comments and questions welcome...
ID:	35454   Click image for larger version
ID:	35455   Click image for larger version
ID:	35456   Click image for larger version
ID:	35457   Click image for larger version
The Following 7 Users Say Thank You to ademonrower For This Useful Post:
aerohead (01-25-2025), freebeard (01-25-2025), Gasoline Fumes (01-26-2025), j-c-c (01-25-2025), Joggernot (01-27-2025), kach22i (01-26-2025), Piwoslaw (01-25-2025)
Old 01-25-2025, 12:42 PM   #2 (permalink)
This is the most Ecomoddery thing we've seen in days. Thanks. The second sketch is especially well done.
ademonrower (01-25-2025), Joggernot (01-27-2025), Piwoslaw (01-25-2025)
Old 01-25-2025, 02:17 PM   #3 (permalink)
I can see no harm, I like, and it would be interesting what a before and after tuff test would show on the surrounding surfaces of any calming effects of the headlight cover install..
The Following User Says Thank You to j-c-c For This Useful Post:
ademonrower (01-27-2025)
Old 01-26-2025, 03:36 AM   #4 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Now block part of the grill! But only if you trust and watch your temperature gauge!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Old 01-26-2025, 11:35 AM   #5 (permalink)
Cool project.
I was aghast at the gaps around my S10 pickup truck headlights until I realized that is where the engine intake gets it air from.
aerodynamics, headlight covers, volvo 240
