Old 07-17-2013, 09:50 AM   #1 (permalink)
The Waissi Engine
This engine design replaces the crankshaft:
Now for Something Completely Different: the Waissi Engine
The Following 3 Users Say Thank You to NeilBlanchard For This Useful Post:
California98Civic (07-17-2013), Frank Lee (07-17-2013), RustyLugNut (07-17-2013)
Old 07-17-2013, 10:32 AM   #2 (permalink)
I think I love it!
Old 07-17-2013, 12:06 PM   #3 (permalink)
darcane's Avatar
Um, so it's essentially a fancy version of a Scotch Yoke piston engine...
That was done 30+ years ago, and there are functional versions:
AutoSpeed - The SyTech Scotch Yoke Engine
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 07-17-2013, 12:14 PM   #4 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Looks like there might be a net gain in internal friction, or perhaps it's a wash. Loss of connecting rods is countered by the mass of the cam disk thingie, so there might not be much gain there either. It seems to me that the biggest benefit is that the cam's rotating masses cancel one another, which may make for a smoother running engine. (A six cylinder version would wipe that out of course.)
Old 07-17-2013, 01:08 PM   #5 (permalink)
Yeah, Scotch yokes and cam driven pistons and such have been around forever, but they suffered unacceptable friction losses and/or durability issues; I don't see that failure mode in this version.
P.S. The Sytec is neat too, but "limited" funds are the hold-up? They had over 1.5 million to spend every year for 22 years...
Actually Neil should have said this design replaces the connecting rod; it's crankshaft could still arguably be called a crankshaft but more accurately a camshaft.
Old 07-17-2013, 02:07 PM   #6 (permalink)
...beats walking...
One has to wonder about the *life* of those very l-o-n-g, thin, connecting rods between the piston pairs. How many tension/compression cycles can they endure before fatigue and failure happen?
Old 07-17-2013, 02:35 PM   #7 (permalink)
There will be failure points.
A simple run through finite element analysis (FEA) would give you the major failure zones. The uploaded pictures are simply a spacial analysis model. Sytec has run an engine for 60K km. I was thinking bearing pressure zones on the cam pin would be problematical.
Performing engine design analysis for one of the AXP teams, we came to the conclusion that this engine gave little advantage other than the improved dwell time at top dead center (TDC). A long connecting rod, short throw engine could give you the same advantages albeit in a much larger package.
It is beautiful engineering though. And that I can appreciate.
Old 07-17-2013, 02:43 PM   #8 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
What problem is this supposed to fix?
Old 07-17-2013, 02:47 PM   #9 (permalink)
I hit reply too quickly.
The fourth of the pictures shows the creative solution that Waissi has brought to the Scots yoke engine. The bearing area has been increased significantly and a large hydrodynamic area means thin oils can do the job. The large pin could house liquid bathed roller bearings.
There are some good improvements of merit in this engine.
Old 07-17-2013, 03:04 PM   #10 (permalink)
Connecting rod angularity issues and reduced piston skirt friction. Also I'd imagine the ring pack can be held more square in the bore so maybe tolerances and sealing can be tightened up. Looks like the whole engine package can also be made more compact, rigid, and light.
