11-29-2017, 04:50 PM
Warming the coolant with exhaust?
I am thinking about building a "coolant warmer" to warm up the engine more quickly. My idea is to transfer heat from the exhaust header to the coolant until the engine warms up. One way I thought of to do this is to wrap copper pipe around the tubes on the exhaust header and run coolant through it. I would install a valve so I could allow or block coolant flow for winter or summer. Warming the engine up quicker could only help its efficiency and longevity. What do you think about this idea?
11-29-2017, 04:57 PM
Rav4 - '21 Toyota Rav4 XSE 90 day: 48.58 mpg (US)
You should probably have a bypass for the exhaust after warm up instead of blocking off coolant I could see the left over coolant cooking in the pipes and sludging up the tube
11-29-2017, 05:00 PM
Not only cooking, but it would turn into a bomb as it passes the boiling point of the coolant and pressure builds. There are a few threads on this though. If you do some searching there are several ideas on how to do it.
In fact, I just added this mod to the 65+ mods list:
http://ecomodder.com/forum/fuel-econ...cations.php#69
There are a couple links there, but there are more threads on this topic too.
11-29-2017, 05:11 PM
65+ Vehicle modifications for better fuel economy - EcoModder.com
Cool! I don't see how it would turn into a bomb though because the radiator cap won't allow more than ~16 PSI of pressure to build up in the cooling system. Also, when did you add it to the 65+ mods list? I looked at the list this morning and I swore I didn't see it this morning!
11-29-2017, 05:31 PM
Haha, I just did it this afternoon. I'm going to be adding a bunch of the warm up mods from my the fast warm up compilation thread. I've just been trying to gather some links to threads.
http://ecomodder.com/forum/showthrea...ead-35830.html
11-29-2017, 06:08 PM
http://ecomodder.com/forum/showthrea...ger-29085.html
All you need to do is control exhaust flow.
You can't just shut off coolant flow when you don't want any more hot coolant.
12-02-2017, 02:08 AM
I thought i had posted the video link here before.
Vw are already doing this, they have a water cooled exhaust manifold.
You could maybe repurpose an egr valve to blow on the radiator or oil pan?
12-02-2017, 10:00 AM
The first-gen Insight has a water-cooled exhaust manifold too. It's cooled full-time, and the car just runs the same radiator as 4-cylinder cars do (it's a 3) to make up for the added heat.
12-02-2017, 10:14 AM
#9 (permalink)
Yup, that's the video that gave me the idea. As for repurposing the EGR to blow on the radiator or oil pan, you would create a huge exhaust leak that would effect 02 sensor readings, and also cover it with soot. I don't think that the EGR valve is open when the engine is cold anyway. It is only open under certain conditions, like a light load cruise.
12-02-2017, 12:47 PM
#10 (permalink)
If the thermostat shuts coolant flow thru the engine off until it's hot, how do you gain efficiency? Asking for a friend...
I do like the EGR valve idea, maybe you could copy DOAX idea and heat the oil pan and trans ?
The Following User Says Thank You to MightyMirage For This Useful Post:
