05-16-2015, 10:03 PM
#11 (permalink)
So he should go out there with a screwdriver and increase the valve overlap?
05-16-2015, 10:36 PM
#12 (permalink)
Not before doing some calculation to figure out the best overlap. And that works easier for engines with VVT at both intake and exhaust, such as the Mazda SkyActiv-D.
05-16-2015, 10:42 PM
#13 (permalink)
How about shoving a potato up the tailpipe?
Seriously. WTH?
05-17-2015, 02:21 AM
#14 (permalink)
Eco-ventor
Diesels typically come with a variable potato known as an EPR.
05-17-2015, 09:42 AM
#15 (permalink)
http://ecomodder.com/forum/showthrea...ler-29085.html
Repurpose an EGR cooler for fast engine warm up or instant cabin heat with out external power.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
05-17-2015, 07:25 PM
#16 (permalink)
When the engine is cold. Does it help to heat up the common fuel pressure rail with an 12V 500W silicone heater? So the diesel is hotter when injected? Or instead of the common rail, the metal fuel line from the rail to the injector?
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011 + 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
05-17-2015, 08:22 PM
#17 (permalink)
Why not heating the tank instead (like it's done in some heavy trucks)?
05-17-2015, 10:26 PM
#18 (permalink)
Because it is easyer and les energy heavy to heat up 0,05l of diesel and a total of only 2,5l for the longest rout i need to drive (home-work). Then heating up 70l. All powerd by the alternator.
I can drift
The Following User Says Thank You to TimV For This Useful Post:
05-18-2015, 04:33 AM
#19 (permalink)
I'm still not so sure about the safety of heating the high-pressure rail. Where else could you fit that heater?
Anyway, what are the factory-fitted cold start aids into your car? Just the glowplugs? What do you think about a grid heater?
05-18-2015, 05:37 AM
#20 (permalink)
This maybe the best idea yet.
Perhaps run a heart exchanger on the exhaust?
