Old 04-09-2022, 06:18 PM   #41 (permalink)
Oyuki - '90 Toyota Corolla TX
The trmperatures around central america are tropical most likely year around. No tank heater. Only a heat exchanger from coolant line to preheat fuel. Wonder if the heat radiation from the engine would heat the fuel rail more than having armaflex on the fuel rail as the armaflex would keep some of the warmth from the heat exhanger fuel heater though it might block the heat radiation it would be absorb fromnthe engine area. Hmm.
1990 toyota corolla TX 1.8 Diesel sedan
40 MPG @ 50 km/h /31 mph highway
Old 04-09-2022, 07:22 PM   #42 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
build a small fire under the engine?
Old 04-09-2022, 11:06 PM   #43 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
When I had my diesel a 1,500W tank heater worked pretty well.
Old 04-12-2022, 12:07 AM   #44 (permalink)
Possibly a wrapped fuel rail would receive fewer heat radiation from the engine, yet if the fuel was pre-heated it would be more worth to wrap the fuel rail, so maybe it's not the best option for you.
Old 04-13-2022, 02:06 PM   #45 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
You should buy the exhaust heat recovery system (EHRS) off a gen 3 prius and install it on your diesel.
https://www.energy.gov/sites/default...11_barrieu.pdf
They are pretty much worthless on pick and pull Priuses so i assume you might pay $50 to cut it out and take it.
If I understand correctly the EHRS is part of the warm up cycle on the Prius until it hits 150F and then it goes to normal and the EHRS cuts out.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 04-13-2022, 02:17 PM   #46 (permalink)
90 day: 29.78 mpg (US)
