Old 10-12-2008, 11:43 PM   #1 (permalink)
jeepin xj (pro jeep ecomodder/hypermiler) - '95 JEEP CHEROKEE XJ
Last 3: 21.58 mpg (US)
What do you think about a crank scraper for FE?
oR do you even know what they are, they bolt to the main caps on the crankshaft sometimes or right to the oil pan bolts, they stop the spray of oil that flies off of the crank while it spins. Has been proven to increase horsepower and FE over time, reduces parasidic loss. My quesion is for 30.00 bucks would you do it? it would go onto a 95 jeep cherokee 4.0 I6
here is the website
Crank Scraper
Old 10-13-2008, 12:48 AM   #2 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Typically these things are only effective under hard acceleration, and if thats the case your fuel economy is out the window anyway. They provide no benefit under cruising conditions. I suppose they might have some benefit if you go up very steep hills a lot but thats it.
Old 10-13-2008, 08:36 AM   #3 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
Or, you can run 1/2 qt low on your oil to keep the crank counter wts from splashing into the oil. I do this on the cars I race and they are a tiny bit quicker AND helps eliminate oil foaming.
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
Old 10-13-2008, 08:44 AM   #4 (permalink)
Its not worth it for the low rpm driving that you should be at while driving for FE. Run a bit lower on oil like ATaylorRacing said and you'll get even better results.
Old 10-13-2008, 12:13 PM   #5 (permalink)
90 day: 51.82 mpg (US)
The only person I know of who's running a scraper is CoyoteX. It's one of those things you can't easily quantify (at least not A-B-A anyway).
Old 10-13-2008, 12:49 PM   #6 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
If I may make a correction (albeit trivial ), I believe it is a windage tray, not a crank scraper, however they are similar in function.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 10-13-2008, 10:02 PM   #7 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
I have a crank scraper and a windage tray on my car
Never been able to show an improvement as a result of it, so I always say if you have the oil pan off it is cheap and one of those things that can't hurt but it is really not worth the effort to do unless you are already in the motor doing work.
The theory behind them is decent. The tiny oil drops hitting the spinning crank take energy away from the rotation, but in reality at under 3000 rpms there just isn't enough stuff splattering around to matter. You might get a 0.01% increase in efficiency at low rpms.
Old 10-13-2008, 11:04 PM   #8 (permalink)
yea i got ya, if the oil pan was leaking i would do it, but i guess ill wait for the day
Old 10-13-2008, 11:08 PM   #9 (permalink)
Red
Red's Avatar
The 4.0 doesn't spin high enough for a scraper to be any help. Plus the main brace girdle more or less does the same thing. Not sure if yours had that or that was part of the 00-02 updates
Old 10-14-2008, 09:25 AM   #10 (permalink)
DieselMiser
ConnClark's Avatar
Actually its not there to prevent drops from hitting the crank. Its there to keep oil sloshing up from the pan from hitting the crank. Preventing drops from hitting the crank is futile because the drops come from the main and rod bearings. Some of this leakage is necessary to splatter some oil on the cylinder walls to provide lubrication to the rings.
Crank pulley removal AndrewJ Off-Topic Tech 17 06-27-2008 07:40 PM
