Old 06-05-2023, 08:34 PM   #61 (permalink)
Primitive Technology
I think he starts with a rock and a stick. ....and pants.
Meanwhile: Major Hardware is 3d printing hubless PC cooling fans: I made a HUBLESS PC fan and it’s so loud!
And Robert Murray-Smith is making graphene out of milk: 1948 Graphene - Making it And Using it
Two wrongs don't make a right, but three lefts do.
Old 06-07-2023, 02:30 PM   #62 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Making fuel from plastic is no different than a sill or pyrolysis
How to turn plastic waste into diesel fuel cheaply - Energetic Forum
Depending on your feedstocks you end up with sulphur free k1 kerosene to D3 diesel.
You can use up to about 20% of this “fuel” in an older gasoline engine
Or 100% in an older diesel
The Japanese home appliances called the “Blest machine “ is no longer manufactured but the company is still around
The Following User Says Thank You to rmay635703 For This Useful Post:
freebeard (06-07-2023)
Old 06-08-2023, 10:09 PM   #63 (permalink)
A 297-page thread? Yikes.
Also the type of plastic is important, you can use only plastics that have pure hydrocarbons in them and nothing else, such as polyethylene and polypropylene. PVC should not be used as it contains large amounts of chlorine that is very toxic and would corrode the metals in your reactor. Also PET bottles are no good as they contain additional oxygen and we need the process to be in non oxygen environment. So only use plastics that contain only carbon and hydrogen.
Chlorine....and suphur with tires. Biomass would be promising.
With plastic we get up to 95 liters from 100kg of plastic and there is nothing else than hydrocarbons in it.
Does this mean it's 100% consumed (and less dens than water), or is there residue?
