Old 06-05-2018, 09:24 PM   #11 (permalink)
90 day: 49.01 mpg (US)
I have only slept four hours a night for the last few nights. RedDevil, does that say that CO2 benefits plants as long as they have enough other nutrients?
Hah, I can better that.
Knee inflammation meant I slept less than 7 hours total over 3 consecutive days (in fact burning the midnight oil right now) AND my dancing skills have suffered; I'm for work in Romania limping about...
C3 type plants may benefit if other nutrients suffice. C4 plants are already beyond their needs.
Sleep well
Old 06-06-2018, 08:39 AM   #12 (permalink)
There was a recent study that showed crops lose nutrition when there is higher carbon dioxide.
Old 06-06-2018, 08:46 AM   #13 (permalink)
Errr... like this one?
Originally Posted by RedDevil View Post
Yeah. Well if it were that simple.
https://www.independent.co.uk/news/science/carbon-dioxide-emissions-environment-plants-climate-change-fossil-fuels-co2-emissions-a8342521.html
Basically there are 2 types of plants: those who move CO₂ actively towards an enzyme (RuBisCO) that absorbs it to prevent it from erroneously taking on oxygen and wasting energy, the so-called C4 plants; and plants that do not (C3 plants). ...
... It seems that this perplexing result may be because as time went by, less nitrogen was available to fertilise growth of plants in the C3 plots and more in the C4 plots. So the effect was not just due to the plants themselves but also to their interactions with the chemistry of the soil and its microbes.
Old 06-06-2018, 06:33 PM   #14 (permalink)
What this is overlooking is the temperature dependence of photosynthesis. C3 efficiency starts dropping around 25C, and shuts down entirely around 45C. C4 photosynthesis works at a bit higher temperature, peaking around 35C, but even it shuts down around 55C: https://kuensting.org/school/bb/cell...osynthesis.htm
So you put enough CO2 into the air to raise temperatures into this range (even if only in the tropics), and then goes a chunk of the biosphere. And of course it's a positive feedback: fewer plants recycling CO2 means more goes into the atmosphere, which means more temperature increase, which means even less photosynthesis...
Old 06-06-2018, 06:54 PM   #15 (permalink)
Good stuff James, I'll have to read up on it more.
What history tells us though is that 99% of Earth history has had higher concentrations of CO2 than we currently have, and our fossil fuels came from plants that flourished during times of high (average) CO2. Were actually near the low point in CO2 concentration in a geologic sense.
This isn't to say the rise is good for humans, only to say it isn't necessarily catastrophic for life in general accept in the short term pressure to adapt rapidly to the change. In the long term, life won't even notice the change in CO2.
Since we're more concerned about the wellbeing of humanity, it's this context that warming matters.
Old 06-06-2018, 08:36 PM   #16 (permalink)
There also is a dependency to CO₂ levels; higher CO₂ allows photosynthesis at higher temperatures in C3 plants and reduces their water usage.
So on the one hand CO₂ raises the global temperature which will increase the size of regions where temperature is the limiting factor on photosynthesis, on the other hand it allows some plants to make use of conditions that would otherwise impede them. Provided nutrients suffice.
Old 06-06-2018, 11:58 PM   #17 (permalink)
Via Xist:
He gave light to the plant with a fiber optic cable which filtered out UV light, a process called ‘Himawari Sunlighting’. He also added pressurized CO2 in a gasket around the stem and root system .... Within 2 years, the tomato plant had reached 16 feet tall with 800 tomatoes. In 16 years, it was reported at 45 feet tall with 15,000 tomatoes.
This could be important in jurisdictions where the number of tomato plants is restricted by law.
It also calls into question all those statistics about airborne CO2.
Two wrongs don't make a right, but three lefts do.
Old 06-07-2018, 01:02 AM   #18 (permalink)
90 day: 30.54 mpg (US)
Some politicians must really not like tomatoes!
Old 06-07-2018, 10:28 AM   #19 (permalink)
It must be the carbon dioxide and not the Himalaya lighting.
Tomato plants grow in a few months to the top of the greenhouse anyway, if properly cared for. So?
One dubious claim can blow away decades of meticoulus scientific observations.
If it is more in line with your preferences.
Old 06-08-2018, 02:18 AM   #20 (permalink)
What history tells us though is that 99% of Earth history has had higher concentrations of CO2 than we currently have...
99% of Earth's history starting when? From the beginning, about 4.5 billion years ago, you've got about 2 billion prior to the Great Oxygenation Event. The Cambrian Explosion and serious multicellular life didn't get going until ~530 million years ago, so that's about 88% of Earth's history used up before we get to anything much more complex than pond slime.
Depends on what sort of life we're talking about. Deep-sea vent communities probably won't notice much. Those of us living closer to the surface might do well to read up on the Permian-Triassic Extinction, which is the closest geological model we have to the current situation: https://en.wikipedia.org/wiki/Permia...tinction_event
