Old 05-09-2010, 08:48 PM   #31 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
it doesn't smack of great mpg, but I still like it
Old 05-12-2010, 12:35 PM   #32 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by silverinsight2 View Post
Hmm, identical drivetrain to the GMC motorhome.
Winter daily driver, parked most days right now
Summer daily driver
Old 05-12-2010, 03:09 PM   #33 (permalink)
The front end of that thing is an Olds Toronado, circa 1969. My dad had a '69 Toronado, bought brand new January '69. They never could quite get the front end alignment sorted out, too much toe-in, and it would not exceed 80 mph despite 400hp and an otherwise not too bad shape for its day. 6-8 mpg, maybe 9 mpg at highway speed. With an Airstream glommed onto the ass end, this rig might get, oh, 5 mpg.
Anybody know of a modern-day RV along the Ultravan line, which reportedly got 16-19 mpg 40 years ago?
Or, perhaps better, a cargo van or small 2 axle truck that comes stock with a good shape, but suitable for further aero improvements and internal refit for RV use?
Old 05-12-2010, 05:37 PM   #34 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
The little Toyotas reportedly get really bad fe. Surprisingly bad.
Its because they are way too underpowered. I passed one recently and it was obviously struggling on the flat section just to maintain 55.
Old 05-12-2010, 06:03 PM   #35 (permalink)
dcb
needs more cowbell
dcb's Avatar
this one claims 25mpg, has a stick shift though, dunno
dunno if the "underpowered" card makes a lick of sense, its a lot more complicated than that.
Old 05-12-2010, 06:30 PM   #36 (permalink)
TheEnemy's Avatar
Thats what I passed. I don't believe 25mpg under any real world driving for a second. Maybe on a fluke, but not even at 55mph steady should it be able to get 25mpg. Seriously, my pickup without all that extra weight and stuff hanging out in the wind got a max of 28 at 55mph, I usually get about 24 at 75ish.
If a car has to be driven at full throttle it will/should run rich, unless its been modified to do otherwise, and it will burn more fuel than a larger engine that is producing the same power at a lower throttle. When moving several years ago my father inlaw helped us move with his full sized truck, under similar loads my mileage droped from 26 at the time to 17, his droped from 20 to 18. He actually burned less gas because I was straining my engine too much, and his was just chugging along just fine. We even dropped down to 60mph for most of the trip.
Old 05-12-2010, 06:58 PM   #37 (permalink)
dcb
needs more cowbell
dcb's Avatar
I'm skeptical because most cars are much too low on load on the bsfc chart because they are overpowered. adding a bunch of drag (load) should bring it back towards the "sweet" spot, though total consumption still goes up. Even with enrichment, it is usually better to have too much load than too little.
so, if it had a saturn engine , if the thing makes enough hp at 2500 rpm and 124.8nm to keep moving then it would be a real good match.
Old 05-12-2010, 08:06 PM   #38 (permalink)
This thing is the working definition of what NOT to do, aerodynamically,
Modification of it would start with a trip to the crusher, a la Breaking Bad episode a couple of weeks ago.
Now, does anybody know of any RV or truck sorta like the Ultravan, i.e., designed with at least some aerodynamic efficiency in mind, of, say the past 20 years? I have in mind a search for a good used RV motorhome, with nice gentle curvature in its sheet metal sorta like a VW microbus, only bigger.
Old 05-12-2010, 08:21 PM   #39 (permalink)
dcb
needs more cowbell
dcb's Avatar
lol, oh yah, aero
that aerostream mashup made me think a teardrop trailer/metro mashup would be sorta cool. if you scaled it up to something caravan sized it might still be pretty good on the mpg and have room for a table/bed.
Old 05-12-2010, 09:25 PM   #40 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Well, considering they haven't made those things in a coon's age it ought to get some respect for still being on the job. I still see them in the wild. Amazingly durable. Most that I recall speaking with say 20+ mpg is typical. Hell I've got enough horsepower to haul my camper 100 mph if I wanted to. But I've also got the horse-sense to keep it at 55. It may not be about struggling...
Cheers
KB
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
