Old 07-17-2008, 03:51 AM   #11 (permalink)
Miata - '93 Mazda Miata
90 day: 34.79 mpg (US)
Originally Posted by meemooer View Post
I think it's all about how comfortable you are behind them
A persons comfort level and safe distance can be 2 different areas.
You should factor in your overinflated tires and remember that your braking distance will be longer(slower to a stop) than properly inflated tires.
Old 07-17-2008, 04:03 AM   #12 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Geo Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Buick Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
I think that you kind of touched a spot here, but I believe the answer to your question will only come with you trying both ways. I know that with my Metro I get better at 55 without drafting than 60 or more drafting, but that could just be because over 55 winds my RPMs up so much.
Old 07-17-2008, 04:41 AM   #13 (permalink)
6th Gen Coupe - '02 Honda Accord EX 4 cyl
90 day: 28.01 mpg (US)
Zombie Accord - '98 Honda Accord EX
90 day: 24.71 mpg (US)
Ol' Red - '96 Ford F-150 XL
90 day: 14.43 mpg (US)
Get a scangauge and see.
Old 07-17-2008, 05:38 AM   #14 (permalink)
stang - '90 Ford Mustang LX
90 day: 27.46 mpg (US)
I would love to try the scangauge but my car is obd1. I have been considering a vacuum gauge, but I don't think that would help us in this situation anyway. Thanks anyways guys. Maybe I'll just try both over the next few months and see how it works out.
Old 07-17-2008, 08:14 AM   #15 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by WheresMyGas View Post
remember that your braking distance will be longer.
I don't believe that is a correct statement. Do you have a source?
Old 07-17-2008, 08:15 AM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
The scangauge plain won't work out on your obd1 car. Build ye an MPGuino
Old 07-18-2008, 03:56 AM   #17 (permalink)
All the tests I see so far only go up to 35psi. I believe overinflated tires(over max sidewall) would have a longer braking distance because of the smaller contact patch to grip the road.
Do you have a reliable source for your disbelief?
This is all I could find for now
http://www.rma.org/tire_safety/tire_...ips/summer.cfm
http://www.edmunds.com/advice/fuelec...0/article.html
Old 07-18-2008, 09:49 AM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
Show me some test data (not editorial hogwash) to back up your asserion, i.e.:
Old 07-18-2008, 10:24 PM   #19 (permalink)
I've read it and Im confused that in autocross people don't set their tire pressure higher than a few psi since they would love maximum braking to improve their times.
It is measuring traction but "gradual braking" is not used to stop as fast as you can(neither is immidiate braking which would induce a skid). Looks like barry the tire expert isn't fully convinced either.
Barry's Tire Tech
"Dry Braking & Wet Braking:
Both of these tests were conducted using a traction trailer – pulled behind a truck. A brake is gradually applied to the test position on the trailer until the tire locks up and instrumentation on the axle measures the peak torque and then the stabilized slide value. For the wet portion of the test, water is sprayed on the ground in front of the tire at a prescribed rate. This generates a consistent water depth. This is a common way to conduct traction testing.
These results are a surprise to me. Given the results of the wear test, I would have expected the traction values to peak at some pressure and then drop. Perhaps it is the nature of the braking test and perhaps a different set of values would have been obtained if a test had been conducted on a circular skid pad using a vehicle – but they didn’t do that, so we don’t know."
Old 07-18-2008, 10:44 PM   #20 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
I run a vacuum gauge and I can pull the same amount going 10mph faster when i'm drafting @ a safe distance. Its not worth it for me because of the rocks and such that get kicked into your windshield.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
