Old 06-05-2015, 10:56 AM   #1 (permalink)
Beginner Hypermiler
Gas Bicycle - '89 Spartamet Bicycle
Last 3: 194.19 mpg (US)
A Swift - '98 Suzuki Swift
90 day: 37.18 mpg (US)
Beater car 2 - '01 Suzuki Swift Summum
90 day: 25.79 mpg (US)
Send a message via MSN to SwiftAnon
Question Will this shark fin antenna help?
i have the antenna on my car unscrewed but the base is still there will this help my mpg?
For vw polo shark fin antenna excellent design car antenna special for vw polo hatchback free shipping-in Aerials from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Old 06-05-2015, 11:40 AM   #2 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
no Its a lot bigger, I doubt you could see a real world difference anyways.
Old 06-05-2015, 12:24 PM   #3 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
+ 0.025 mpg max IMO
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
Old 06-05-2015, 02:12 PM   #4 (permalink)
90 day: 56.53 mpg (US)
You can make a wing shaped sleeve for the antenna too.
Theoretically that can reduce drag by 90%, see http://ecomodder.com/forum/showthrea...rag-25378.html.
I made a plastic wing shaped sleeve (painted it black, that's not in that link yet) and found it made no measurable effect, as expected.
I guess it helps a tiny bit.
Made of leftovers, if it saved me 0.01 liter of gas it already earned itself back several times over
Old 06-05-2015, 04:17 PM   #5 (permalink)
The PRC.
Yes, it will help, because you will look sexier and therefore be more relaxed and drive more efficiently.
On the other hand get a good one and you get DAB ability ?
The Following 2 Users Say Thank You to Arragonis For This Useful Post:
Cd (06-06-2015), mcrews (06-05-2015)
Old 06-05-2015, 04:22 PM   #6 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Will it help? Possibly. Yes, it will have more frontal area, but if the drag coefficient is better, total drag may be lower. (I'm reminded of an Automobile Magazine article comparing the current S-class to the Volkswagen Golf--the Mercedes has lower total drag even though it's a much larger car).
Will it help measurably? Probably not.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 06-05-2015, 04:27 PM   #7 (permalink)
The PRC.
Aw, just get one - they look really good
Old 06-05-2015, 10:14 PM   #8 (permalink)
Arragonnis' correctnesss aside, no. The shape is wrong, it has a blunt trailing edge and would require extensive boattailing. Compare the various images at https://www.google.com/search?q=purp...+wi-fi+antenna; and consider the function, for example:
Cellular, GPS, LTE, WiFi & PCS Mobile Sharkfin Antenna
Arragonis (06-06-2015)
Old 06-06-2015, 07:52 AM   #9 (permalink)
09 Toyo Yaris HB (Huevos)
Certainly won't help radio reception unless it actually has the fractal antenna wire inside. as for mpg there are already lots of opinions
The Following User Says Thank You to 2009Toyotoad For This Useful Post:
digital rules (06-07-2015)
Old 06-06-2015, 11:49 AM   #10 (permalink)
Cd
Ultimate Fail
Cd's Avatar
If you put a partial grille block on the car, you will see savings a hundred times greater than anything you will see by changing your antenna.
The Following 3 Users Say Thank You to Cd For This Useful Post:
Arragonis (06-06-2015), BabyDiesel (06-06-2015), digital rules (06-07-2015)
