02-22-2008, 08:47 PM
MechE
Woo Vacuum Pump!
So I just aquired a vacuum pump from a friend... on loan
It's a rotary vane type pump that will pull 20"Hg or 25"Hg intermittently.
So, I don't want to fry this pump while vacuum bagging. Therefore, I need a vacuum limit switch. Having very little budget to do this, I'm posting this question to everyone. Any solutions?
Here's the one I came up with... And I do recognize the Rube Goldbergian properties of it. Hook up a syringe to the vacuum lines and on the plunger, hang a weight. Below the weight, place a micro switch. When there's vacuum, the weight hangs above the switch and the pump is off. If the system loses vacuum, the weight falls the switch is closed. This will cost me about $5 (10 cents for syringe and ~$4 for switch), $10 at the most including electrical components.
Diagram
Thoughts, suggestions, alternatives? Anything blatantly obvious I'm missing?
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
02-22-2008, 09:07 PM
Jetta - '05 Volkswagen Jetta
I applaud your art.
02-22-2008, 11:41 PM
MechE
Originally Posted by Mike
I applaud your art.
Should I frame it?
02-22-2008, 11:44 PM
a spring, and a screw would do the same thing as a weight, and could easly be adjusted.
02-23-2008, 11:59 AM
Lurking footless halls
Don't fry the pump, that would suck. oh wait...
but seriously, you could obviously calibrate it by varying the weight. I'd be concerned about the friction of the syringe plunger. Maybe a lubricant would help as long as it doesn't attack the rubber seal.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
02-23-2008, 02:55 PM
Originally Posted by trebuchet03
Should I frame it?
I think it belongs on the fridge door.
05-14-2010, 05:47 AM
vacuum pumps uk
If you want to find out more about finding a vacuum pumps uk there's some information at the bcas website, it's short for British Compressed Air Association.
Hope it helps.
great drawing, loks like something out of scrapheap challenge
05-14-2010, 06:01 AM
#9 (permalink)
thanks
05-14-2010, 08:59 AM
#10 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
It's very simple... and it might even work.
If you could design/build an electronic switch, a MAP sensor would also work, but you'd need an Arduino or something similar to read the signal and control the circuit.
Basically, set it up so that the MAP sensor's reading controls a switch. Under 16" of vacuum, turn on, over 18", turn off.
You take an old pill bottle, drill a hole in the top of it, insert the MAP sensor (which needs a 12V/ground as well as a sig output) then drill another hole for a nipple, to which you would attach your signal hose. Run the signal hose in a Tee with the bag hose, so they "see" the same vacuum both inside the bag and inside the pill bottle.
When the pill bottle's vacuum reaches 18", the Arduino kills the circuit (the pump's circuit - leave the MAP turned on) and when the bag falls below 16", the Arduino turns the pump circuit back on.
This way, there's nothing mechanical to align, nothing can slip, break, or otherwise fault, and you can build in redundancy that if the system drops below a certain vacuum level for X time, to turn off the circuit.
Say, for instance, a hose cracks. Pump starts pumping, because vacuum is below 16"... pump can't get anything higher than 10" after 30 seconds, Arduino shuts down pump to prevent damage.
