Go Back   EcoModder Forum > BenArcher006's Profile > Albums
2006 Ecomodded Saturn Vue
2.2L Ecotec 4cyl
Manual 5spd
140 000 kms
Ultragauge and Vacuum Gauge
Complet front grille block
Front bumper gaps and opening evened out
Lowered and widen front air dam
Radio antenna delete
Warm air Intake
Pass side mirror delete
Driver side smaller motorcycle mirror
Undertray partial belly pan
Roof rack rails delete
More to ecomods to come
After lowering springs
Before lowering springs
Just new Hid 6000k headlights!
Wires coming from the injectors power wire.
Relay location under the dash
Injectors kill switch (now attachec to the shifter knob)
Nice smooth belly pan V2.0
Nice clean roof without rails
Truck's look without the Roof rails
Front belly pan
Passenger side mireor delete
Smaller driver side mirror
Wai V 2.0
Inside Air box view
Front end  gaps blocks
Radio Antenna has been cut
Underbumper opening partial block
Engine still needs air
Evened out faux grilles
Upper front grille gaps filling
Air dam mod
With only the grille block
