Go Back   EcoModder Forum > billyfogg's Profile > Albums
1999 Mustang Ported V6
I port & polished of my 99 V6 about a year ago inspired by my want collect and solve for all the data involved with the numbers given from the manufacturer data sheet by figuring horsepower, from fuel flow, BSFC, RPM, Combustion Chamber Size, Compression Ratio, Volumetric Efficiency and a number of other values I can't remember off the top of my head. I am a DYNO without a DYNO haha
Stage 3, Test. Very first Circuit I ever created. It's ugly but It works. Next to come is an OBDuino. I'm Stoked
Stage 2, Solder
Stage 1, Parts
The money shot
35th Anniversary Cousins, I worked at a body shop if your wondering how I got creative control over the parking lot haha
This is the Beaut' Fresh from Wyoming after the move to Seattle. She remains cosmetically the same to this day.
After it was all back together.
Just my clean Piston
I only polished the Main Intake Ports. Making them bigger would have been best fit with I new, higher lift camshaft and a performance tune. Both are...
Hard to see, After Lapping the Valves
Lapping the valves with some fine grinding compound.
My Heads after the porting. Majestic, they are haha
After I cleaned the carbon off my pistons
This is the exhaust port, Stock the diameter was 3cm
