Go Back   EcoModder Forum > Christ's Profile > Albums
1998 Chevy S10 brake rotor/wheel bearing how-to
Remove cotter pin.
Spindle Nut is 32mm, (1.125" (1 1/8")), but it's only finger tight.
Remove wheel bearing retaining washer
Remove wheel bearing, careful not to drop it.
Caliper bolt/Guide pin location
Upper and lower points of caliper, backside accessible.
3/8" Inside Hex (Allen-type) Caliper Guide Pin Bolt.
Helps to have a parts tray, with one side for new parts, one side for old parts.
Tools that you will need.
Hang the caliper up, don't leave it hang on the brake line.
Rubber/Latex/Nitrile/Etc Gloves. Use them.
Propane Torch - for stuck lug nuts.
1/2" Drive 450 Max PSI Impact - 3/4" Socket
3/4" Socket/1/2" Drive 24" Breaker Wrench.
Used/New Rotor/Hub assembly.
Wheel bearing grease/Stainless steel spoon.
0809091511
