Go Back   EcoModder Forum > jomelmaldonado's Profile > Albums
Toyota Echo MPG Sensitive Cruise Control
Securing the cruise control servo assembly to the vehicle  permanently with bolts.
Washed engine bay area where you can see the cruise control.
Securing the throttle to the cruise control servo cable.
Engine bay area view of the cruise control.
Engine bay area, where you can see part of the vacuum hoses that go to the cruise control servo assembly and the interior of the car to supply vacuum...
Fuse distribution block to take power for the cruise control.
Kick panel area, here you can see part of the wire harness for the cruise control, the vacuum hose and the Ford MAP Sensor.
Cruise control switch and mode selector switch for constant speed or constant MPG.
Partial view of the wiring harness for the cruise control. The brake light wire was tapped to the cruise control wire harness by removing the lateral...
Securing the cruise control servo assembly to the vehicle  temporary with tie raps.
