Old 07-26-2012, 11:16 AM   #1 (permalink)
136.5 mpg on my Yamaha C3
I purchased a 2007 Yamaha C3 scooter last fall and have been experimenting with different tire pressures, riding habits, and various things and have so far managed a best average of 136.5 mpg. I'm super excited about having triple digit fuel economy, especially with so little effort. I run the tires at 40 psi and have found that the best thing to do is just run it as close to 40 mph (the limit of the speedometer) as possible, and shut if off at stop lights (engine off coasting isn't really very helpful, since it has a CVT with no neutral, though I do shut off the engine while coasting). It's a hoot to drive and I can commute to work and back all week on less than a gallon of gas.
This is my first post on this forum and I'm glad I joined. I really enjoy reading about other people's projects.
The Following 2 Users Say Thank You to jared1970 For This Useful Post:
littlecars (07-14-2015), sendler (07-17-2015)
Old 07-26-2012, 12:00 PM   #2 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
The only thing i would be concerned with is shuting off the engine while moving. I don't know anything about CVT's but I would think it needs to be lubricated while moving
Old 07-26-2012, 12:12 PM   #3 (permalink)
CVTs on scooters are purely mechanical, using a rubber belt and weights that slide along a ramp as centrifugal force is applied. No lubrication needed. Plus, because there is no neutral, the engine is turning with the transmission; turning the engine "off" while moving really only serves to kill the fuel pump so that the injector isn't being supplied with fuel while decelerating (the C3 is fuel injected). As long as the engine is turning over, the oil pump continues to operate, it's just not being powered by gasoline but rather by the rotation of the rear tire as you decelerate. So, even if the transmission required lubrication, it would be able to get it.
Old 07-26-2012, 03:24 PM   #4 (permalink)
The 50cc engine and some improved aerodynamics could approach 200 mpg.
Old 08-05-2012, 06:23 PM   #5 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Maybe not with a CVT wich is one of the less efficient means of transmiting power ...
I went from a Helix to a GN to gain 10% of FE.
Same capacity, same use ...
Old 07-14-2015, 11:44 PM   #6 (permalink)
Less gas=longer road trip
littlecars's Avatar
the Jelly Bean - '07 Toyota Yaris
I also have an '07 C3. New air filter, synthetic Mobil 1 oil and now a new back tire that I can run at 40 PSI (purchased today). Lessee what she'll do!
Old 07-15-2015, 02:58 PM   #7 (permalink)
Some discussions on the scooter aerodynamics lead to this sketch of a body for my Honda Elite project some day.
Old 07-16-2015, 08:00 AM   #8 (permalink)
Try seeing if they have a set of Dr. Pulley sliding roller weights that fit your bike. Should help even more
Old 07-17-2015, 05:03 PM   #9 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Nice numbers.
Old 08-07-2015, 09:19 AM   #10 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
You should try full throttle while engine off coasting, that should help you "coast" farther by reducing pumping losses
